C7Carbon | Race Edition Front Splitter for C5 | 3D DESIGN, input welcome!!
Old 12-01-2017, 06:46 PM
jimtway
jimtway's Avatar
Originally Posted by FYRARMS
Just make sure you leave the center of the spoiler/splitter open for cooling. The ACP nose with integrated center opening is sweeeeeet, but I would rather just add a nice spoiler rather than replace my entire front bumper.
This is a Tway Motorsports (TM) splitter which can be run with or without spacers, however the spacers are designed to mate directly to a World Challenge bumper. The larger opening is absolutely required for cooling if you are going to track your car.
Mounting is also something that has to be addressed. There is a mounting kit that goes with the above TM setup. One cannot simply take a flat splitter, or integrated splitter with spacers and bolt it to an OEM bumper. The OEM bumper is too flimsy and weak to take any load at speed. World Challenge bumpers are either fiberglass or carbon fiber, and are significantly stiffer than the OEM plastic bumper.
Marc@Vettenuts.net (01-30-2018)
Old 12-02-2017, 01:55 PM
C7 Carbon
Platinum Supporting Vendor
C7 Carbon's Avatar
Thanks again guys! we are taking notes of all your suggestions. Our design team has been swamped with our new product development, sorry again for the wait, we'll make sure post the new renders for the upcoming C5 projects as soon as possible!
Old 12-12-2017, 09:28 PM
C7 Carbon
C7 Carbon's Avatar
Hey guys we are excited to share with you the first renders of our upcoming C5 vented front splitter. Let us know what you think!
Old 12-12-2017, 11:26 PM
FYRARMS
FYRARMS's Avatar
Received 3,236 Likes on 1,590 Posts
Looks are subjective and will obviously be a matter of personal taste. However, I find that rendering to look too "busy". I am sure you were going for a look that included some support in the middle of the splitter, but the dual vertical supports shown give the splitter 3 openings, which just isn't working for me. I definitely prefer a cleaner appearance when one center opening is used.
Old 12-12-2017, 11:44 PM
FYRARMS
FYRARMS's Avatar
Forgive my super-fast MS Paint edit...
ErikwithAK01 (12-13-2017)
Old 12-12-2017, 11:55 PM
Mike94ZLT1
Mike94ZLT1's Avatar
Agreed, 100%. Too busy.
Old 12-13-2017, 12:16 AM
Proletariat designs
Proletariat designs's Avatar
I like the width of the opening but not the middle fins. If you keep them, I think you sold try to mirror the lines of the front Liscence plate filler. I'd make the angle on each side parallel Instead of the outer sides being fairly straight. It gives a harsher angle and don't fit the curves in the bumper already. I do like seeing the progress
Old 12-13-2017, 08:57 AM
ErikwithAK01
ErikwithAK01's Avatar
I concur. Too busy. A opening as wode as the center splitter would be preferable, and farther out in front of the bumper by a little as well. It won't generate ANY downforce while it is overshadowed by the nose of the car.
Old 12-13-2017, 09:18 AM
neutron82
Support Corvetteforum!
neutron82's Avatar
Received 1,261 Likes on 1,056 Posts
I feel the same, I like the large opening in the middle if you get rid of the small pieces that separate it... I also think it extends down a little too far which makes it look too bulky and will sacrifice ground clearance on a street car... I would probably like it more if it extended out a bit farther too and have the ends meet the edge of the bumper instead of leaving part of it exposed
Old 12-13-2017, 10:03 AM
FASTFATBOY
FASTFATBOY's Avatar
I dig the first rendering and know why it's made that way, at speed it needs it for rigidity. At speed you don't want it folding down like C6 cars do.
On the car that will look much different than staring straight at it from eye level.
Old 12-13-2017, 02:58 PM
C7 Carbon
C7 Carbon's Avatar
Thanks again for all the feedback, here is an updated version of our Vented front splitter, let us know your thoughts!
The following 2 users liked this post by C7 Carbon:
blue02ZO6 (12-13-2017), FYRARMS (12-13-2017)
Old 12-13-2017, 03:26 PM
neutron82
neutron82's Avatar
that looks MUCH better, I like it a lot... fastfatboy does bring up a good point about stability at high speed... personally I would need something that won't fall apart at 180+
Old 12-13-2017, 03:57 PM
  #33
work_truck
work_truck's Avatar
whats with the downward curve?
Old 12-13-2017, 04:52 PM
  #34
killian96ss
killian96ss's Avatar
Getting better, a little more lip on the sides would help.
Steve
Old 12-13-2017, 07:51 PM
  #35
Proletariat designs
like this much much better. I like the slight point on the lip. I think the lip is too much for a street car ( killing ground clearance with that overhang) and needs more for a track car. I'd like to see a rendering of the lip wrapping around to the sides. If the lip does grow out it probably needs some turnbuckles for structural integrity.
again over all like this much better
Old 12-13-2017, 08:57 PM
  #36
FYRARMS
FYRARMS's Avatar
Muuuuuuuch better!
Old 12-13-2017, 09:21 PM
  #37
neutron82
neutron82's Avatar
just noticed the ends are still cut a bit short from the edge of the bumper, is there a reason for this?
FYRARMS (12-14-2017)
To C7Carbon | Race Edition Front Splitter for C5 | 3D DESIGN, input welcome!!
Old 12-14-2017, 01:18 PM
  #38
C7 Carbon
C7 Carbon's Avatar
Thank you for your feedback guys! we'll make sure to post updated renders shortly
Old 12-14-2017, 02:36 PM
  #39
charger21
charger21's Avatar
C5 of Year Finalist (track prepared) 2019
From a looks standpoint, I like the latest rendering. But people need to understand that to have a functioning front splitter, you should be able to stand on it once it is mounted. If they are going for looks only, then it is a very nice looking piece.
Old 12-14-2017, 07:04 PM
  #40
C7 Carbon
C7 Carbon's Avatar
Here is the latest update! The following renders show both versions: the splitter without the under tray and WITH the under tray [Race Edition]
Let us know what you think, we are all ears!
Quick Reply: C7Carbon | Race Edition Front Splitter for C5 | 3D DESIGN, input welcome!!
