01 help neede!!
Old Nov 1, 2017 | 11:25 AM
Upsman84's Avatar
Upsman84
Default 01 help neede!!
No starter cranking!! New battery an all works but won't turnover? Ran fine yesterday?? Please help ASAP!! Wife needs her car!! Thank you!
Old Nov 1, 2017 | 11:32 AM
knewblewkorvette's Avatar
knewblewkorvette
Even though it's a new battery, I would suspect the battery. Sometimes they set on a shelf for awhile so it might not be fully charged.
typeav's Avatar
typeav
1 - Starter
2 - Alternator
3 - Powertrain Control Module
Old Nov 1, 2017 | 11:46 AM
Upsman84's Avatar
Upsman84
Originally Posted by typeav
1 - Starter
2 - Alternator
Even if it only has 24,000 miles ? Ran fine yesterday an today is nothing?
Old Nov 1, 2017 | 12:06 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Couldn't have said it better...
Old Nov 1, 2017 | 01:45 PM
Upsman84's Avatar
Upsman84
Originally Posted by 8VETTE7
Most likely cause of NO CRANK on a C5 are:
Starter/starter solenoid failure
Bad battery or loose battery connections including at the starter
Ignition key NOT being read correctly (Security light on dash will remain illuminated with key left in the ON position)
Ignition switch problems
All the above are common issues with the C5 ir-respective of vehicle mileage.
With these in mind an drove fine yesterday which one would you try first??
Old Nov 1, 2017 | 02:30 PM
3sACROWD's Avatar
3sACROWD
As others have said BATTERY. Even though it drove fine yesterday, if a cell goes bad, the result can be instantaneous. Check the cables on the battery. If tight, take the battery to AutoZone or some place similar and have it load tested.
Old Nov 1, 2017 | 02:31 PM
3sACROWD's Avatar
3sACROWD
The other thing to try is pull your codes.
Old Nov 1, 2017 | 03:06 PM
runner140*'s Avatar
runner140*
Not trying to be a buster....but, you keep saying "it ran fine yesterday", C5's can run well one day and not so well the next.
You need to check ALL of the above.
Old Nov 1, 2017 | 04:07 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
The order I listed them in is the order I would suspect the cause most likely is.
Easiest to check is the battery since you can remove it and have it tested free of charge. If you have and know how to use a digital multi meter the battery voltage across the battery posts should be 12.7 to 12.9 volts or more for a good battery at full charge. Have the battery load tested at any parts store and most do load testing free.
Also the pellet in the key not being read correctly is easy to check. As I said above if the SECURITY light on the dash remains ON with the key left in the ON (not start) position for say 15 seconds, the key pellet or the sensing rollers in the key cylinder are the problem. Correct operation of the SECURITY light is that when you insert the key into the ignition and turn the key to ON the security light should come on and then quickly go OUT.
If the problem is the starter or starter solenoid you can also check that out fairly easily. Place the end of a broom handle on the body of the starter (not the solenoid) and while a helper holds the key in the start position give the other end of the broom handle several very hard wacks with a 3lb hammer. No love taps. Solid wacks.... If the engine immediately cranks then the problem is the starter or starter solenoid.
Testing the ignition switch is more difficult. Here is a link to the procedure that Bill Curlee, Forum's resident electrical wizard, recommends:
http://forums.corvetteforum.com/1568186703-post64.html
Agree with the above. Another simple check which falls in line with the key pellet is to try your second key (assuming you have a 2nd).
Old Nov 2, 2017 | 04:53 PM
Clancy209's Avatar
Clancy209
Check the grounds, Hope you didn't leave something on all night, lights, radio, interior lights
To 01 help neede!!
