Any thoughts
Old Nov 6, 2017 | 09:31 AM
Mlcharlestonsc's Avatar
Mlcharlestonsc
Default Any thoughts
Any thoughts on this Corvette. Seem to good to be true??
http://www.bellsautosales.net/mobile/view/18976
Good buy bad buy or stay away?
Old Nov 6, 2017 | 09:42 AM
Mayor111's Avatar
Mayor111
Check out the basic history here:
https://www.vehiclehistory.com/pagin...YY22G845113794
Looks like its been sold at (4) different dealerships since 2014...that sounds fishy to me...
Old Nov 6, 2017 | 09:52 AM
Velocity_Vette's Avatar
Velocity_Vette
Only driven 3,000 miles in the span of eight years from '07 - '15? Not completely unheard of I guess but considering this Corvette is nothing special I would want to know why. It also looks like it's been all over the East coast.
The body kit is a Greenwood kit that was initially fairly popular when C5s were still new (Greenwood was an independent Corvette racer). You don't see them around much in complete form and it's completeness makes me question if it was installed to replace say some damaged fascias and such. The kits nowadays new are NOS and I'm not aware of anyone reproducing them so I would assume it was likely installed some years back.
Old Nov 6, 2017 | 10:54 AM
Mlcharlestonsc
You both have backed up my suspicions and I believe this is a "don't touch with a 10 foot pole".
Old Nov 6, 2017 | 11:03 AM
Toys4Life C5's Avatar
Toys4Life C5
St. Jude Donor '21
That wing takes the value down quite a bit. If you are close and interested, I would take it for a LONG test drive and look over the extensive bodywork to make sure it was done correct.
Old Nov 6, 2017 | 11:40 AM
3sACROWD's Avatar
3sACROWD
If you like the way the car looks, go check it out. Do a thorough review of it and make the final decision based on your gut feel. If it doesn't feel right, it isn't. The fact that you're already questioning it is your first clue.
Removing the wing will require a new rear fascia unless you know someone with incredible body work skills. I'm guessing the same for the front. The mods are not easily reversed without replacement components so you have to like what is already done.
Old Nov 6, 2017 | 08:30 PM
redzg's Avatar
redzg
$14K for an auto with lots and lots of peel-and-stick doo-dads. I think you can do better.
Old Nov 7, 2017 | 03:46 AM
Rob 02's Avatar
Rob 02
14K for a low mileage '04? Why so cheap?
The rear fascia is easily replaced.
Old Nov 7, 2017 | 01:01 PM
knewblewkorvette's Avatar
knewblewkorvette
$14K for a 2004 with only 34K miles. That's cheap! If everything checks out, I'd jump on it!
Old Nov 7, 2017 | 02:23 PM
Chris Draper's Avatar
Chris Draper
From: Gilbert, Arizona Currently Own: 1998 Coupe YouTube: My Corvette Life
The only reason I would think it has such low miles and has been passed around to 4 dealerships in 3 years is the modifications. It's looks like a AutoZone Special. That's a hard sell for any dealer.
Old Nov 7, 2017 | 02:51 PM
Roddy13's Avatar
Roddy13
lol that thing is hideous. That's why it isn't selling.
To Any thoughts
