[Z06] C5 Z06 Upgrades
Old Nov 11, 2017 | 11:10 AM
CoachPaul's Avatar
CoachPaul
Default C5 Z06 Upgrades
So I bought my first Vette a year ago, a 33K mile 02 coupe, and am hooked. Just upgraded to a 7500 original mile 04 Le Mans Edition Z06 literally last night.
With that in mind, a question for you experts out there. On my coupe, we did a Billy Boat exhaust with an X pipe and an Air Raid, Carb Legal (I am in CA) Dry Cold Air Induction. I was also told to put on C6 Z06 Shocks and C6 Z51 sway bars with metal end links. Never got to that.
So here's my question to you guys. I am not changing the Z06 Titanium exhaust. But might do the Cold Air Induction. Is it a worthwhile upgrade on the LS6? Also, does the Z06 have metal end links on the sway bars (I guess they are plastic on the coupe)?
Thanks in advance all. Looking forward to 10+ Years with my new toy.
PL
Old Nov 11, 2017 | 11:17 AM
95wht6spd's Avatar
95wht6spd
Yes, metal end links.
I am not up on all the CAI options, as I have a SC, but I know the Callaway Honker had good results. I would only do if I also put on headers, and like you I have the stock Ti mufflers, with Kooks headers, X, cats.
The 04Z has the best of the stock C5 shocks, would leave them and the rest of the suspension as it, unless you plan to track it hard.
Do the CLBP mod, if not already done.
Old Nov 11, 2017 | 11:26 AM
CoachPaul's Avatar
CoachPaul
What is the CLBP mod?
Old Nov 11, 2017 | 11:32 AM
druz06's Avatar
druz06
column lock bypass?
Old Nov 11, 2017 | 12:11 PM
CoachPaul's Avatar
CoachPaul
Ahh, that one bit me on the first car. Column locked up outside a restaurant. Had to have it trailered to dealer. They didn't want to warranty it. I guess it was a recall. They tried to say "Recall has expired". Pardon my French but I called Bull **** on them. Safety Recalls don't expire and I said, the steering wheel locking up and not steering the damn car might just be considered a safety issue. Bottom line, they fixed it. Anyway, I am guessing with 7000 miles, this one may need it too. Thanks
Old Nov 12, 2017 | 01:31 PM
dbgoodwin's Avatar
dbgoodwin
they definitely didn't fix it, GM doesn't have a real fix for the column lock issue.
Just get an LMC5 and drive worry free.
Congrats on the upgrade!
Old Nov 12, 2017 | 02:38 PM
zeevette's Avatar
zeevette
I'd recommend a Vararam for your CAI choice. Then headers and a tune.
Old Nov 12, 2017 | 03:38 PM
CoachPaul's Avatar
CoachPaul
Default Pictures
Here are the 2 cars, old and new (new old anyway). The coupe is an 02 with 37K on it. The Z06 is an 04 LeMans edition with 7600 miles on it. The coupe is for sale if anyone's interested. Magnificent / Immaculate car
Old Nov 12, 2017 | 05:04 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Steering column lock fix, 1-4 skip shift fix, CIA + adding a hood seal.
i added the low/hi beam relay. and a Hinson shifter.
Heres some links
http://www.c5registry.com/MembersOnl...4/announce.htm
http://www.vettefacts.com/C5/2004.aspx
http://www.c5registry.com/MembersOnlly/production.htm
http://www.corvetteactioncenter.com/...06/z16prod.php
Old Nov 12, 2017 | 06:56 PM
CoachPaul's Avatar
CoachPaul
Default Questions
Heres some links
Questions, What Column lock fix did you do, what hood seal did you add and is there a prob with the hi/low beam relay in these cars?
Old Nov 12, 2017 | 07:59 PM
Spaceme1117's Avatar
Spaceme1117
Here is what I recommend (in no particular order)
1. Header and catted X-pipe (keep stock Ti exhaust)
2. Good quality CAI.
3. MGW shifter.
4. 1-4 Skip shift
5. Tune
Old Nov 13, 2017 | 10:11 PM
Yost44's Avatar
Yost44
Spaceme you hit my list right on the spot. I may also add a cam but I haven’t decided yet. I’d like to do it all at once so I only have to get it tuned once.
Old Nov 14, 2017 | 06:48 AM
Spaceme1117
I had also considered a cam at one point but decided against it. At 3118 lbs stock and with 405 crank HP, my Z06 still scares me a little bit when I get on it.
I just can't imagine this lightweight car with 50 or more HP/TQ.
Old Nov 14, 2017 | 11:22 AM
CoachPaul's Avatar
CoachPaul
How much can a good tune do for the LS6? I saw a you tube video of some guys dyno-ing a c5 z06 at about 350 HP at the wheels, they did a tune, got it up to 360. And then did some more and got it to about 370, again, at the wheels. Is 20 HP possible by a talented tuner?
Old Nov 14, 2017 | 12:41 PM
Spaceme1117
20 HP just from a tune sounds a bit of a stretch to me but is possible. 10 is more realistic of a gain.
The best use of a tune is in combination with other mods to maximize the gains from those mods making everything work together at the fullest potential.
Combine a tune with a set of headers and a good intake and now we are talking a solid 25 to 35 WHP gain.
Old Nov 14, 2017 | 03:33 PM
MY03C5Z's Avatar
MY03C5Z
That’s the route I went with mine, it was stock when I got it.
Old Nov 14, 2017 | 09:27 PM
dbgoodwin's Avatar
dbgoodwin
i don't know about 20 hp on a stock car, but with headers I could see a baseline 350 then up to 370 after tuning. That's roughly where I am, 376 Rwhp 386 rwtq.
To C5 Z06 Upgrades
Old Nov 14, 2017 | 09:49 PM
jonnyc's Avatar
jonnyc
lt headers and most cold airs are not smog legal here in california.unless the o.p has a hook-up on smog or wants to swap parts every other year it's not worth doing any mods.
there are turbo and supercharger kits that have carb numbers if you want more power
Old Nov 15, 2017 | 12:55 AM
JrRifleCoach
http://www.complianceparts.com/lmc5description.html
http://www.westcoastcorvette.com/p-7...04-c5-z06.aspx
http://shop.radioflyerinnovations.co...arness-003.htm
No problem with the relays. This kit keeps the lo-beams on when switched to hi-beam.
Old Nov 15, 2017 | 10:32 AM
WA 2 FST's Avatar
WA 2 FST
Congrats on an awesome find! As much as you have enjoyed your coupe, you will be thrilled with your Z06.
I'm an original owner, bought it back in 1/02, and have been very pleased. As far as, "first order of business mods", you have some excellent responses above. CLB will bite you (as you already found out on your coupe) at some point. Might as well address that now. You can eliminate the skip-shift feature with a tune... no need to purchase hardware on that.
Way back in '02, a tune and CAI was worth a solid 15+rwhp on my car. But tuners are probably better/more precise now.
Two years after I bought my car, I went with a twin-turbo setup... car is a blast. Big $$, yes, but I've gotten my money's worth as long as I've owned it. No issues at all. 725+hp.
I would do heads/cam/exhaust as time and $$ allows. These cars are very tractable and can handle the additional power with a deft right foot.
