Temperature control unit
Old Nov 16, 2017 | 09:42 PM
awches's Avatar
awches
Default Temperature control unit
success on re soldering the 8 resistors on the circuit board. Found one plumb loose. Plugged it back in and hooked up battery and the panel lite up. YES. two for two on resoldering jobs as the ECBM was the first last month.
Now, onward with the radio swap out. ;-)
Also remove the Sirus radio set up which took more time than any other part. The single din pioneer will do all I want to do for sure.
Old Nov 16, 2017 | 10:11 PM
FX VETTE's Avatar
FX VETTE
Congrats and good for you
Old Nov 17, 2017 | 01:19 AM
Nothing like doing the work yourself and saving a bunch of money.
Old Nov 17, 2017 | 04:01 PM
awches's Avatar
awches
Carrying on with the project of changing out the stocker radio for a Pioneer unit kin to the one in my truck happened today. The taking out of the brace was a bit of a hassle but out without much mess.
Then sorting the wires , hooking up the wiring harness that Crutchfield built for the conversion then installing the radio. Hooked up the battery to test and it's all good. Nothing to adjust. So, batt disconnected again, and temperature unit plugged in and installed. That's it for the day.
Old Nov 17, 2017 | 04:22 PM
SG Lou's Avatar
SG Lou
Old Nov 17, 2017 | 04:58 PM
awches's Avatar
awches
When installing the Sirius unit, they installed the head unit in the ashtray door. i got that changed up but missing the little piece or spring that hold the door closed against the the ashtray lid. Guess I'm gonna have to dig to see what that looks like.
To Temperature control unit
