Help me choose a C5, please.
I've decided to start looking for a C5 with manual tranny and Z51 package. Some people in the autocross forum suggested I get a Z06, but I really like the targa top and think that the base C5 will offer more than enough performance for me.
I've read the stickies and they were very helpful, but I have some questions that weren't answered in them. I've seen some mention of different kinds of seats available. Were there just two, standard and sport, or is there another? Do they come in cloth, most I've seen in photos look like leather or vinyl. What are your recommendations?
People seem to really like the HUD. Is it worth seeking out, or is it nice but not that big a deal? Is it reliable?
I saw mention of a C5 being lowered on "stock bolts". What does that mean exactly, and is it mechanically sound to do that?
Any options or packages that I'm overlooking? What would you recommend for a car more on the performance side and less on the luxury/creature comfort side?
What does your car have that you really like or don't care much for? Thanks for everyone's advice.
BTW, I forgot to mention I don't want to do many mods to the car other than basics like tires, brake pads, etc. Just don't have the desire to spend a lot of time under my car these days. I also don't care how well my car fits into any autocross class, I do it just for fun, so if I'm under-prepared for my class that's ok.
Another BTW, silly question, but I've been noticing that some C5s have a trim line that runs from the trailing edge of the door to the cove (is that what they're called, like on the older Vettes, the recessed scoop on the side of the car?). Which cars have this, is it an older/newer thing, or an option, or part of a package or what?
I have the HUD. IMO it's nice to have but not a deal breaker. I almost never use it. YMMV.
If you want a targa top, than I'd definitely go with a Z51. The extra 50hp or so from an LS6 isn't hard to add to an LS1. There are other differences like wider tires, and slightly closer gear ratios in 1st through 4th, but you can't beat going topless on nice days. I never considered a Z06 because I like the coupe's looks better. $15,000 should by a nice Z51 6 speed. $20,000 will buy a nice Z06.
The hud can be added for 600 dollars and it's really just a nice gimmick...I have it in my cars and I had them added but it's not a big deal.
Figure both standard seats in the corvette blow..including the optional seats.
Maraad is a vendor that for $750 has a nice update for the seat that I would consider in time. Otherwise just pull the seat belt out all the way and then let it retract during each autoxross ...it locks tight and keeps you pretty snug in the seat.
I'd recommend a high mileage well cared for c5 z06 or z51.
Low mileage examples are overpriced.
I'd recommend buying a 2002 or newer something about the body control module not being available to replace on earlier c5s...
I'm not sure if 2001 c5 s BLM is still available but I remember earlier c5 s no longer have that part available so buy a 20002 or newer..don't worry about mileage.
The rings on 2002 c5 s are better designed as well. The 2001 rings were too loose and often allowed oil past the rings...
I had a 2001 c5 z06 that had to get re ringed under warranty because at 5000 miles it was drinking oil like crazy..who needs that crap..
Good luck and have fun.
I have 115k miles on my c6 z51 manual purchased new like my two c5 s and it's been utterly reliable. So good in fact I can't bring myself to sell this car..
I'd recommend buying a 2002 or newer so,ethi g about the body control module not being available to replace on earlier c5s...
I had a 2001 c5 z06 that had to get resigned under warranty because at 5000 miles it was drinking oil like crazy..who needs that crap..
You'd be better off upgrading on your own with the C6 Z51 bars.
The z51 is much more like the Z06 than it is the base car, at least for the later cars. I haven't found any specs for the earlier cars, but I'm sure they're floating around somewhere.
(unless you want to be called sparky) My eighth Corvette has the HUD. I rarely use it and can live without it for sure.
Sound like you may be into autocross. Be prepared to do a ton of $$$$ mods or the Miatas will eat you for lunch.
The base coupe is better looking than the Z06 or FRC and has better aerodynamics but 50hp and thousands $$$ less.
Happy shopping!
After I bought my car, I found the rear sway bar links were shot. The factory parts were plastic. The fronts were metal and still holding up fine, but I went ahead and replaced front and rear links with the beefier aftermarket i-beam variety and the car stays absolutely flat through any corner you throw at it. The Z51 really doesn't need bigger sway bars. They are very close to Z06 specs. Unless you go all the way with coil overs, the shocks (due to age) and sway bar end links are probably the only suspension needs for auto-x events.
Z06 seats are horrible under any load. Turning and braking you will slide around. I replaced mine immediately.
Otherwise great car. Lots of performance. Shocks and brakes are easy to replace.
I'm with you on this one. I despise the look of the FRC so much that I couldn't buy a C5Z even if a tremendous deal fell into my lap...my C5 MUST be a targa top...
Manual transmissions on base targas are fairly low production numbers. Ratio is roughly 19%-25% production depending on year. Remember the market for this car and you'll get your answer as to why so many were automatics. All 1999-2000 fixed roof coupes and 2001-2004 Z06s are manuals so you'll find manual transmissions easier with those models but you'll pay more. Automatic targa fastbacks are always cheaper.
If your plan is to track the car you'll want the base seat simply to not have all the electronics in the sport seat. Regardless C5 seats are pretty terrible and you'll probably want to upgrade even with light auto-x duty. The stock seats do a terrible job of holding you in at speed.
Z51 is way overrated. It was important when it was the only option to have when C5s were new. Nowadays you can throw all sorts of better upgrades including virtually every suspension option from a C6 including Z06 and ZR1 components. (C6s are very similar to C5s in they're effectively evolutions, not revolutions, of the Corvette design). And C6 components are very cheap nowadays. Do a search and you'll find a ton of C5 owners that have performed very competent upgrades for little money.
HUD is a bit of a novelty but it has it's issues; falling out of place, that sort of thing. It also wasn't available until later '99 when clusters became "HUD enabled".
C5s use transverse leaf springs (from side to side) for suspension, so to lower the car you just turn the bolts on the spring up to alleviate the tension. You can only go so far though, and you want to turn them evenly side-to-side not all the way up to maintain the corner weight. More hardcore packages usually go to coil overs.
the moldings on the side are called BSM - body side moldings. They were an option on C5s. Personally I don't like them and my C5 doesn't have them. What modern car do you know of that has protruding body moldings other than something made in the 80s/early 90s? They date the car a bit.
I advise you to read up a bit more on some of the more glaring tech issues with C5s. Primarily EBCM issues that 1997-2000 cars have, discontinued parts like the 97-00 SWPS (steering wheel position sensors; C5s use magna-steering that is speed sensitive), and especially column lock issues which if you're wanting a manual C5 you're going to probably deal with.
I'd also advise you to actually drive a targa if it's what you want. The targa top is a bit useless with speeds over 45-50 MPH. Anytime I've actually gone on a trip I leave my top on. The only time it comes off is local city driving where I know my speeds will be relatively low. Anything at highway speeds with the top off the wind and noise just turns into this symphony of unwanted mess.
