[Z06] Clutch advice
Old Nov 25, 2017 | 11:05 PM
Mvmiller28's Avatar
Mvmiller28
Default Clutch advice
I need to get a new clutch installed in my 02 zo6. I need a clutch that will hold 550 wrhp. What should I get installed how much do you think labor and materials will cost? I will be driving on the street and doing a little autocross. Im currently dynoed at 460 to rear wheels and I want a clutch that will hold 550 so I have a little room for more power.
Old Nov 25, 2017 | 11:20 PM
sabastian458's Avatar
sabastian458
Monster single disc level 2 or 3. Do a full kit with slave and remote bleeder. I’ve always performed my own labor, but I’d expect to pay $800-1500 depending on the place and the area you live.
Replace the rear main while there.
Old Nov 28, 2017 | 12:07 AM
ASRoff's Avatar
ASRoff
McLeod twin disc and done....
Old Nov 28, 2017 | 07:42 AM
LiteraCola's Avatar
LiteraCola
+ 1 on the McLeod. I'm running the RST with no issues on 610 wheel.
Old Nov 28, 2017 | 08:30 AM
akanitro's Avatar
akanitro
I'm doing the McLeod RST right now.
Old Nov 28, 2017 | 01:55 PM
WA 2 FST's Avatar
WA 2 FST
I have run a Spec 2/3 setup years ago back when I did the twin turbo setup (13 yrs ago)... good clutch, but there are certainly better out there now. But it did very well.
I didn't wear it out, but later, when I had things pulled part for a new ZR1-spec trans, I went with the DYAD clutch. I really like it.
I'm at 650+rwhp/620rwtq.
Old Nov 28, 2017 | 06:30 PM
LoneStarFRC's Avatar
LoneStarFRC
McLeod RST
+3
Old Nov 28, 2017 | 09:24 PM
Moto One's Avatar
Moto One
I'v had both the Monster 2, and McLeod RST. Monster 2 if you were drag racing, it's mass would help with launch. I used an Monster 18lb flywheel with the 2. RST and super light flywheel (9lbs) quick rev's, fast rev match shifts (both up and down), takes a little more rev's and slipping to get moving. Best used for track.
My 2 cents.
Mark
Old Nov 29, 2017 | 08:51 AM
Nokones's Avatar
Nokones
McLeod RST Twin Disk with McLeod Aluminum flywheel behind a Lingenfelter SBC 427 with 646 HP at the crank holds the power very well and is very streetable just like a stock clutch. And this is my Autocross car. I had a Tilton Triple Disk 5 1/2" and I hated it. It was a piece of stuff and I was so glad to take it out. I have used McLeod products in the past with no problems at all.
Definitely, the McLeod. The RST will take your horsepower with no problem.
Yes, I know that this is a C5 ZO6 discussion group and I am not a troll. The above info was about my C4 Autocross car and I do have a C5 ZO6 still with the stock clutch. My ZO6 is just a grocery getter and not an autocross car.
To Clutch advice
