M6 Tranny Question
Old Dec 11, 2017 | 09:56 AM
jost6453's Avatar
jost6453
Default M6 Tranny Question
I purchased a C5 M6 a few months ago and have this fear, that when going up through the gears, that I might hit reverse when I'm heading for 5th. Is there any 'lockout' that prevents this when traveling at speed? I haven't hit R yet. But I kinda think about it every time I go for 5th. Thanks.
Old Dec 11, 2017 | 10:32 AM
f6john's Avatar
f6john
Very little to be concerned about in my experience. Fourth to fifth always seems very smooth and natural. Spring loaded detention seem sufficient to keep you out of reverse.
Old Dec 11, 2017 | 11:04 AM
Kylar's Avatar
Kylar
Nothing to worry about, there is a lockout. You would have to fight really really hard to even try, and then you would probably bend/break something before actually getting it in.
Old Dec 11, 2017 | 11:49 AM
nsogiba's Avatar
nsogiba
There is a lockout that is electronically actuated to engage above 2mph. You can't get in there.
Old Dec 11, 2017 | 11:54 AM
dbgoodwin's Avatar
dbgoodwin
And you will know if that lockout ever fails, assuming you have the stock shifter.
Search around for "grinding going into 5th"
its very easy easy to hit reverse without the lockout with the stock shifter, but you really won't damage anything unless you really try to force it in there.
Old Dec 11, 2017 | 12:06 PM
socal_Dad's Avatar
socal_Dad
Great thread! I've been wondering about that myself. Good to know there is a lockout in there.
Old Dec 11, 2017 | 12:14 PM
jost6453's Avatar
jost6453
Great info here. Many thanks to all! I have wondered if I am just 'good' (ha!!!) or if there was a tranny angel that prevents me from hitting reverse. I've never had an issue but the concern was always there. Thx again.
Old Dec 12, 2017 | 04:55 AM
98C5P's Avatar
98C5P
My lockout solenoid was faulty when I took ownership on my Z, I will tell you...you will know it when it is not working!!!!!! Buzzed reverse a few times.... I installed a new one, and reverse gate is completely blocked off....
Cheap part and easy fix.
Old Dec 12, 2017 | 09:04 AM
striper's Avatar
striper
If your lockout isn't working you will find out quickly. When trying to get in to reverse to back up it will take two hands and a lot of force to jam it in to gear. It happened to me and that's how I found out about it. If you look at the shop manual, it tells you to drop the trans to replace it. It's quite hidden on top of the trans where you can't see it. By poking around you will find it. Having done a clutch on my car once, there was no way I was taking out the trans just to replace such an inexpensive part. Using the feel around method, I was able to change it without actually seeing what I was doing. It isn't easy but doesn't take too much time. It's available on Amazon. I don't remember how much but not much more than $50, I think.
Old Dec 12, 2017 | 09:14 AM
jrp1588's Avatar
jrp1588
As others have said there's a lockout. I will also say, this is the 2nd C5 I've owned, and so far I'm 2 for 2 on faulty lockouts. Neither one was very difficult to get into reverse, but they'd give a good buzz if you missed fifth. I still need to fix it, but I've only missed 5th a couple times.
Old Dec 12, 2017 | 10:03 AM
dbgoodwin's Avatar
dbgoodwin
Pretty sure that they can fail in the locked or unlocked position. One makes it hard to get in, one is like yours.
You must have bad luck
Old Dec 12, 2017 | 10:48 AM
jrp1588's Avatar
jrp1588
Oh well, there are worse problems. I'm not in a hurry to fix it, because frankly, the car has bigger problems. I'm never in a rush to slap it into 5th like I am 1-4. I think on this new car, I only buzzed reverse once back when I first got it, and was like "Oh, so we're doing this again."
I'll fix it after I fix the passenger actuator motor on the climate control, the compressor seals on the AC, get the shifter aligned good, figure out why my e-brake sometimes doesn't work, etc, etc, etc. lol
To M6 Tranny Question
