[Z06] LG GT2 coilover help
Old Dec 11, 2017 | 10:44 PM
Tommygunn5645's Avatar
Tommygunn5645
Default LG GT2 coilover help
Hello, I recently had a set of LG gt2’s installed on a Z06 that is an 80% track 20% street car (road racing). After the install the car was pretty bouncy so I did a search and saw that I could be the result of too much preload. I put the car up on a lift and noticed the driver side springs turn freely and the passenger side springs do not. The car was supposedly corner balanced. Could the difference in the right side vs left side preload be a result of the corner balancing or should it be the same amount of preload on all four corners? If I change the preload will it greatly effect the corner balancing? Thanks for the help. Suspension tuning is voodoo witch craft to me.
