leaking?
Old Dec 20, 2017 | 07:47 AM
Silverwolf_pup's Avatar
Silverwolf_pup
Default leaking?
The other day when i had my hood open on my 02 coupe, i noticed the brake container resivor was leaking, took the cap off, cleaned and inspected, maybe just a bad cap? will replace to see if that stops, and also my windshield fluid has been leaking for awhile at the top. anybody else have this issue? Thanks
Old Dec 20, 2017 | 09:05 AM
runner140*'s Avatar
runner140*
On a 15 year old Vette, there are many plastic/rubber (hoses and belts) parts that need to be replaced. You named a couple. Check out your hoses. ALSO, check out ALL those plastic parts for age cracks.
Old Dec 20, 2017 | 07:55 PM
Silverwolf_pup
Sure will, thanks will replace brake cap container to see if that helps.
To leaking?
