[Z06] 2004 Z06 tires
Old Dec 27, 2017 | 05:27 PM
Maz615's Avatar
Maz615
Default 2004 Z06 tires
Hey all ,
Need some advice . Need new tires for my 04 Comm Z06. My tire place is telling me only option is the GY Eagles due to size and tread pattern. Is there any other brands i can put on the stock wheels with no issues ? Thanks Mark
Old Dec 27, 2017 | 07:27 PM
grantv's Avatar
grantv
Toyo Proxes T1
Bridgestone RE970 IIRC
Goodyear F1
There was a set of the Bridgesone FS here very recently... check now!
Old Dec 27, 2017 | 08:29 PM
MY03C5Z's Avatar
MY03C5Z
Look at 275/40/17 or 255/40/17 for the fronts, they both work fine and open up a lot more choices.
Old Dec 27, 2017 | 09:47 PM
grantv's Avatar
grantv
Definitely... but I personally think the 265's already have too large a sidewall compared to the rear. I'd go 255 before 275. Or if possible, 305 out back.
To me this is noticeable and just doesn't look right (factory sizing):
265-40 sidewall = 4.17"
295-35 sidewall = 4.06"
Old Dec 28, 2017 | 01:13 AM
jonnyc's Avatar
jonnyc
if you get two more rear wheels for the front and run 18's front/rear you will have a ton of options.you could run 265 or 275/35/18 front and 295/35/18 rear.
Old Dec 28, 2017 | 02:46 PM
63Corvette's Avatar
63Corvette
I concur...this is the way to go
Old Dec 29, 2017 | 10:42 AM
Boeuf's Avatar
Boeuf
I was thinking about doing this as well but after a lot of reading and looking at pics, if you use the factory 18x10.5 rears on the front won't the rim stick out a little bit from the front fender?
I could be wrong, just curious, as some have said that in other threads.
Old Dec 29, 2017 | 09:47 PM
jonnyc's Avatar
jonnyc
the 10.5 wheel will stick out 9mm (almost 3/8") further than the 9.5
Old Jan 30, 2018 | 08:42 PM
vettefred's Avatar
vettefred
Skip Shift
Yep....run them on mine and they look fine....could run the later year vette splash shields. Having all four the same allows regular tire rotation and lengthens the life of our tires....
Fred
Old Jan 31, 2018 | 02:13 PM
ZO6 cracker's Avatar
ZO6 cracker
Fred
Hi, Do you have any pics with 18’s all around on your Z06 to post?
Old Feb 1, 2018 | 10:00 PM
ZO6comm2679's Avatar
ZO6comm2679
Jegs sells the Toyo Proxes T1’s in the stock sizes. I just received mine yesterday, $695 shipped for the set. Hopefully going to have them mounted this weekend.
Old Feb 2, 2018 | 09:18 AM
work_truck's Avatar
work_truck
FRC not z06, but they should work.
This is with all rear wheels and 285s all the way around
To 2004 Z06 tires
