Lug nut torque clarification please...
I've been searching and reading old posts and the owner's manual but I'm still confused and unsure about the specified lug nut torque ratings.
I saw a post that everyone was saying 100 ft lbs and then someone said 89 ft lbs.
I'm used to seeing different values for steel, aluminum, and magnesium. Are all GM Vette wheels made from the same material? I test drove one 2002 stamped with "Magnesium" which looked to be the base wheels. What are the Z06 wheels?
I have a 2002 C5 with what I assume are the Z06 chrome wheels. Can someone show me where the torque spec is found. I looked all through the owner's manual and never found it, but maybe I missed it.
Thanks!.
Knowing the error, my 100 ft-lbs is usually about 96.3 ft-lbs last year.
I don’t know why there isn’t a tolerance like 100 lb ft +or - 5 lb ft .
That would make more sense to me. As I have not yet seen a torque wrench that is 100 % accurate across it range
Bfit
The full procedure is, install wheels, hand tighten lugs. Torque lugs to spec (100 ft. lbs.), if You want to do it in 2 steps, that's maybe a little better, 60% (60 ft. lbs.) on the first round, 100 ft. lbs. on the second round. Go in a star pattern, skip a lug as you go around 5 lug wheels twice around. Then drive 50 to 100 miles, then go around the start pattern one more time with torque wrench set at 100 ft. lbs. DO NOT loosen the lugs when checking torque, just go around once and go till the wrench clicks, then stop.
Whenever a wheel is removed, follow the procedure I just outlined. Torque to spec (100 ft. lbs. for Chevys with 12mm lugs), drive 50 to 100 miles, then re-check torque, tightening only. If it clicks before it moves, it's fine. If it moves and clicks, you've worked out any "settling in" that happened. After the first re-check, you're done.
Theoretically, if you mark all 5 studs, all 5 holes in the wheel, and all 5 lug nuts, you might get away without rechecking if you install everything matched back exactly as it was, so you get every nut on the same stud it was on before, and in the same hole in the wheel where it was before. That's way more OCD than most folks.
