Gear box replacement decision
The mm12 parts are hard to get and more money and the gears are unevenly spaced but i like the lower ratio.
i have 2 base model boxes i can pull parts from too make a good box and after looking at gear ratios with a 3.90 ring & pinion i think it would be a better set up
Any one do a similar set up?
( i'm swapping in 07 diff and sub frame also)
