Key fob
Old Feb 3, 2018 | 04:50 PM
dennyg1's Avatar
dennyg1
2nd Gear
Default Key fob
Recently bought a 98 corvette and did not get a key fob with it and I purchased one from a local dealership and went through the process of learning the fob to the car I go through all the steps correctly but it will not learn itse.f to the car
my question is do I have to take it to a dealership to have it programmed?
Old Feb 3, 2018 | 05:29 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Denny - Post your question in the C5 section.
Welcome to the forum!
Old Feb 3, 2018 | 06:31 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Jeff T gave you good advice, check in with the folks on C5 forum. There will be good info there. Welcome!
Old Feb 3, 2018 | 07:25 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome to the forum, Denny!
Old Feb 3, 2018 | 10:56 PM
DebRedZR1's Avatar
DebRedZR1
Moderator
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'17, '21
Moving to C5 General
Old Feb 4, 2018 | 12:34 AM
Are you sure they sold you a fob for the right year?
Old Feb 4, 2018 | 12:36 AM
dennyg1's Avatar
dennyg1
2nd Gear
Yes I checked the numbers myself
Old Feb 4, 2018 | 01:59 PM
CJ1957's Avatar
CJ1957
Default Original working fob???
These are the instructions I used in the past to program additional remotes:
1. Turn ignition on.
2. Turn radio off.
3. Press Driver Information Center(DIC) RESET button.
4. Press OPTIONS button on DIC until display is blank.
5. Press and hold RESET button for 3 seconds.
6. Press OPTIONS button until FOB TRAINING is displayed.
7. Press RESET button to begin programming sequence.
8. Simultaneously press and hold LOCK and UNLOCK buttons on first remote for 13 seconds. Message will appear when remote is programmed. Repeat this step for additional remotes.
9. Turn igntion off and remove keys from ignition.
10. Test remotes.
Disclaimer: If this doesn't work and I may be off base on this but in order to program a new fob you might have to have one original working fob to do it yourself.
If you don't have an original working fob, you have to take it to the dealer to program it off your PCM.
Again, not 100 ‰ sure though.
Old Feb 4, 2018 | 03:41 PM
Route99's Avatar
Route99
Just a note to go with the directions CJ1957 posted; If the FOB TRAINING message cannot be display, you may have a problem with the BCM being configured with the correct RPO codes. If this is the case, you will need someone with a TECH II to reprogram the BCM.
Good luck
To Key fob
