Suspension opinions
Neither should lift your car, unless your current shocks are absolutely shot.
Sway bars are a simple DIY and shocks aren't far behind.
Swaybars:
C5 Base Suspension: 23 mm-front / 19.1 mm-rear / 3.81mm/2.0mm thickness
C5 Z51 (97-99): 25.4 mm-front / 21.7 mm-rear
C5 Z51 (00-04): 28.6 mm-front / 23.6 mm-rear / 4.15mm/3mm thickness
C5 Z06: 30.0 mm-front / 23.6 mm-rear / 4.5mm/3.5mm thickness
C6 Base: ?? mm-front / 22.0 mm (7/8")-rear
C6 Z51: 31 mm-front / 25.4 mm (1")-rear
C6 Z06: 31 mm-front / 28.8 mm-rear
C5 Hotchkis: 31.75 mm-front / 25.4 mm-rear / 4mm/4mm thickness
C5/C6 Addco: 32 mm-front / 25.4 mm-rear
C5/C6 Addco: 35 mm-front / 25.4 mm-rear
C5 Pfadt (Adjustables): 32 mm-front / 26 mm-rear http://www.pfadtracing.com/
C5 Pfadt (Adjustables): 35 mm-front / 28.5 mm-rear (Pfatty)
C5 T1 (GM Racing): 38.4 mm-front / 27.5 mm-rear / 6.35/6.35 thickness
C6 T1 (GM Racing): 38.4 mm-front / 27.5 mm-rear / 6mm/?? thick
Springs:
C5 Z06: 526# Front, 714# Rear
C6 Z06: 531# Front, 782# Rear
C6 Z51: 526# Front, 645# Rear
T1 (C6): 582# Front, 850# Rear
C6 Base: 420# Front, 657# Rear (VBP: 400-420 F / 600-620 R)
T1 (C5): 582# Front, 793# Rear
Pfadt Coil-overs: 425# Front, 575# Rear (Remember: Wheel rates!)
Hyperco HPS (Street): 565# Front (12405HPS), #765 Rear (12406HPS)
Hyperco HPT (Track/Solo): 625# Front (12407HPT), #850 Rear (12408HPT)
VBP Sport 990# Front, 650# Rear
VBP Extreme 1050# Front, 855# Rear
part numbers:
GM OEM Z06 Front Swaybar: 10419094
GM OEM Z06 Front swaybar bushings: 10419095 (2 needed)
GM OEM Z51 Front swaybar: 10424741
GM OEM Z51 Front swaybar bushings: 10424742 (2 needed)
GM OEM Z06/Z51 Rear Swaybar: 10424743
GM OEM Z06/Z51 Rear swaybar bushings 10431951 (2 needed)
GM OEM 2002+ Z06 Aluminum endlinks: 10435298
This link tells how to swap the swaybar:
http://www.ls1howto.com/index.php?article=16
Z06 Front spring: 22178729
Z06 Rear spring: 22188038
Z51 Front spring: 22178729 (note: same as Z06)
Z51 Rear spring: 22179020
Base Front Spring: 22178728
Base Rear Spring: 22179019
How to swap the springs:
http://www.ls1howto.com/index.php?article=20
I have C5 Z06 Sway Bars with Prothane poly bushings and C6 metal end links along with F45 adjustable shocks. What a nice improvement over the FE3 sway bars and rubber bushings with plastic end links that came with the F45 suspension in 1999.
You can replace your front swaybar for a C5 Z06 front swaybar since your rear bar is the same size as the Z06, replace the rubber bushings with ploy and install fresh new metal endlinks. I felt that the C5 Z06 was fine for the street but makes the car feel more planted and firm similar to how my '02 C5 Z06 felt.
