Oil life remaining warning
Seems kinda early for fully synthetic oil.
How many of you go religiously by the OLM warning?
Call it preventative maintenance not waiting till the car tells you to change the oil.
Either way, I'd never go more than a year eirher, but 5500 seemed low.
Oh well... Might as well start a clean slate.
IT has been proven time and time again that the oil life monitors (esp in earlier models) sucks. Oil is cheap. Why would you risk a 10K engine over a $50 oil change ??
From what I have read, the old reliable advice of 3000 miles between oil changes is outdated for today's modern synthetic oils. At least if you're not talking about the most severe use.
I didn't know anything had been proven about the oil life monitors. It's based on an algorithm with rpm and temperature taken into account.
And apparently the earlier model 97-00 oil monitor was conservative because they reprogrammed the oil life to last longer on the 01-04. I assume GM did some serious oil life analysis on the earlier C5s and decided the oil could safely last longer than the algorithm was estimating.
I don't know how anyone manages 10k per change though. Maybe long trips in moderate weather ? I've gotten as few as 4k miles before it went to 0% life, but averages closer to 5k. The owner's manual actually states something like change it within 600 miles after it hits 0%. I feel safe going to 0% before changing it. I typically use Mobil 1 and a high quality filter.
But to be clear, I would still change it at least annually if I wasn't cycling through the oil life meter at least once a year already.
There is a reason, and a good one. When a car is stored for months in a garage that isn't climate controlled, the oil sits and condensation from the fluctuating temperatures is the result. So, the oil gets changed. You think it's wasteful, I don't.
Its so cheap and it feels good to know I'm taking care of it, and it's an easy job.
My wifes car (05 corolla) is a lot shorter interval using conventional oil. I do wait until the monitor reminds us on that one.
Amazingly , the guy that donated his 750+ K mile C5 to the Corvette Museum said that he changed oil when the car told him to. LOL I'm sure he was changing it a few times a year even at that pace.
Just a NEW LS alone is 5-6K...
I'm not going to risk my "fill in the blank" $$ motor for an extra
$39 oil change per year..
I read of all these LS's having oil leaks, sending units, etc going bad
at anywhere from 25K to 75K miles... Valvesprings, Rockers,, Seals Leaking , And the list goes on..
I bet MANY of these issues are avoided when the owners are vigilant on
preventative maintenance ... SO I'll stick with my "over doing it" and keep getting 200k+ miles out of all my vehicles (including 1 ford).
