Potential CE purchase question
Old Mar 5, 2018 | 06:49 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Default Potential CE purchase question
Hey all!
I'm a C4 guy pretty serious (I've been reaching out to sellers) about a C5. I'm interested in a 2004 CE model.
I'm a bit confused as I do my research on interior colors. The "authorities" say that the color is a Shale (greyish tan) but all the cars I've seen have black?
Also, I see some lemans blue cars being advertised as CE cars but without the stripes. Was there a stripe delete option?
Also, how many miles is TOO low and how many miles are TOO many. I ask as with C4s they like to be run regular so a 25k car will need some solid maintenance to bring her up to standard while 50-60k means it was driven regular enough to keep it all working.
Any questions to ask (I know about the steering lock) so I sound reasonably bright.
Thanks!
Old Mar 5, 2018 | 07:04 AM
3sACROWD's Avatar
3sACROWD
I'm not an authority on the CE cars but I believe the coupe and convertibles offered both black and shale for an interior option and the Z06 was just black.
As far as mileage, that is a personal preference. Many have had good luck with low and high miles. The big thing is upkeep. If you find one with low miles, expect to spend some money on fluid changes, hoses and belts, battery, and tires if that hasn't already been addressed.
I bought mine with 167k miles and had to do the tranny at 250k. Everything else has been what I consider routine.
The main thing is to find one that meets your wants and needs and "feels" right. Trust your gut. If it doesn't feel right, walk away. Don't justify your way into a purchase if it doesn't feel right.
There are stickies at the top of the section that are good reading for what to look for when buying.
Have fun and let us know what you find.
Old Mar 5, 2018 | 07:06 AM
3sACROWD's Avatar
3sACROWD
Forgot to mention I have an 03 Z06.
Old Mar 5, 2018 | 07:22 AM
Z06Berlin's Avatar
Z06Berlin
There are both blue and blue with the strip. The strip is for Commemorative edition (2200 cars). Jim
Old Mar 5, 2018 | 07:45 AM
Ron C!'s Avatar
Ron C!
The Coupes and Verts are LeMans blue, shale interior, no stripes. No black interior option. The Z06 is black interior and stripes.
Old Mar 5, 2018 | 09:17 AM
billschroeder5842
Roger that- thanks this is the info I need.
Old Mar 5, 2018 | 09:32 AM
Z06Berlin's Avatar
Z06Berlin
This applies only on the 2004 models. Jim
Old Mar 5, 2018 | 09:41 AM
wayneinvirginia's Avatar
wayneinvirginia
Cruise-In VIII Veteran
The silver stripes were only factory applied on the Z06 Lemans Commemorative Editions (Z16 option code)
Old Mar 5, 2018 | 09:48 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
assuming it hasnt been beaten LS1s are just breaking in at 70K.....these are wonderful motors. 50k would be very sweet spot but dont be scared of a well maintained 70k car
Old Mar 5, 2018 | 12:50 PM
billschroeder5842
So, please help me with this one... I found one I like with 25kish on the clock, It look like it has been taken care. The guys seems pretty upfront and answers my questions, however he shot me this note:
The harmonic balancer has a little wobble to it, not a lot though - that is a known issue with these cars and thought you should know.
I did some quick reading and it looks that while it IS a common problem, will require a replacement? Maybe not a deal breaker, but a definite consideration.
Old Mar 5, 2018 | 02:36 PM
Ron C!'s Avatar
Ron C!
Yes, harmonic balance is a known issue. If left unchecked, it can cause crankshaft damage which equals $$$$$. I had the one on my Coupe replaced at a local Vette shop, around $550 all in. Figure that to be done immediately and the cost factored into you offer.
Old Mar 5, 2018 | 02:56 PM
Bingo! I second the recommendation to read the stickies at the top of this section and the ones in C5 Tech.
Old Mar 5, 2018 | 06:32 PM
steve8's Avatar
steve8
Obviously ask what has been done to the car over the years.
Condition of tires/runflats/or non runflats?
Factory wheels? Some had cracking issues.
Original gas tank? Again, some had issues.
Accidents?
Mine has been a very reliable car and still cleans up well!
Old Mar 5, 2018 | 09:58 PM
billschroeder5842
Is there a PM that can be done or is it a "immediate surgery" situation?
A slight wobble to some is a cataclysmic gyration to others. The car is 3 hours from my home so it will be immediately tested!
Old Mar 6, 2018 | 07:49 AM
Ron C!'s Avatar
Ron C!
No PM, it will just need to be replaced. Sight wobble should be not a to do yesterday, but it should be done sooner than later. Mine had very little wobble, but made a hell of a noise.
Maz615's Avatar
Maz615
Default C5 z06
Seems like 25k shouldn't create a HB problem. I have a CE with 15K and and no problem whatsoever . Check maintenance records. Good Luck !
Old Mar 6, 2018 | 08:32 PM
msandym's Avatar
msandym
Hey all!
Thanks!
To Potential CE purchase question
