I converted my C5 rear turn signals to Sequential. its hardly noticable. got the parts from 1 of the VETTE catalogs. Like your fronts, < but sounds like more than I want to get into. IM an old fart the getting down part is easy, I can just fall down. its the getting up part that I have trouble with. Need to figure out a crane system in my garage
I think I might have been farting more years than you. We all are getting up in age! What part of the country are you? If you want to install these I would be willing to help. It sounds complicated, but once you get into it..it is not that complicated.
Ed
Would you mind providing a parts list for this mod. Also, I was unable to get the vids to work. Thank you.
2000 Supercharged LS1
about the only items that you need to purchase are the 2 sets of led light strips on ebay. (item #s noted) the rest is a little bit of wire for relay bypasses and accessory light feed and some black plastic tape to block emitting light from 2 unused strips.
Well here goes....I will try to explain my sequential install.
I purchased 2 sets of light strips, eBay item #401430516931...
Wiring:
Red to accessory fuse in under hood fuse panel
Black is ground
Blue OR Green tapped into turn sig lite feed at park lite bulb socket (blue = lite flow in one direction, green = lite flow in opposite direction. Only one of these is used on each side)
Yellow not used
I was trying to follow your wiring, but when compared to the manufacturer's directions it seems your list is missing the Red & Black wire for the white DRLs. Could you please explain?
From product description in eBay:
There are 5 lines for the input of the product controller:
1.Red line for positive car battery.
2.Black line for the car battery negative .
3.Blue line for the Left signal, shows yellow color.
4.Green line for the Right sinal, shows yellow color.
5.Yellow line for the Strobe, shows flash white color.
6.Red and Black line for the daytime running light, shows white color.
Nice, but I think they would have looked a lot better if the sequence had been slowed down.
They move so fast that it is almost like a regular directional light, except for a slight movement.
Slow them down a bit if there is a way to do that.
It would be a lot more effective.
Kind of like the red front sequential light on "Kit" in the night rider.
