Help 99 factory CD player doesn't work
Also you put the CD in upside down in the cartridges.
Does the car have a owner's manual?
I believe it's input button to choose from radio, cassette (can't believe they put cassette players in these cars) or CD.
#2 means next cd in pack, I believe #3 brings up next song on cd.
In '99 CDs were still the most popular format. Cassettes not so much.
My CD player has been on almost 100% of the time the last 5 years. The cassette player has never been used.
I tried the cassette player just for kicks when I first got car, but when I moved I trashed the cassettes.
If an error appears on the display, see "CD Messages" later in this section.
1 PREV (Previous)
Press this pushbutton to go to the start of the current track if more than eight seconds have played. If this pushbutton is held or pressed more than once, the player will continue moving backward through the CD.
2 PROG (Program)
Press this pushbutton to select the next CD in the magazine. If a CD cannot be played, its number will be skipped when selecting CDs while using this pushbutton.
3 NEXT
Press this pushbutton to go to the next track. If this pushbutton is held or pressed more than once, the player will continue moving forward through the CD.
REV 4 (Reverse)
Press and hold this pushbutton to quickly reverse within a track. Release the pushbutton to play the passage. The elapsed time of the track will appear on the display.
5 (Dolby)
This pushbutton has no function when playing a CD.
FWD 6 (Forward)
Press and hold this pushbutton to quickly advance within a track. Release the pushbutton to play the passage. The elapsed time of the track will appear on the display.
RECALL
Press this button to see what track is currently playing. Press it again within five seconds to see how long the track has been playing.
SEEK
The left arrow works the same as the PREV pushbutton and the right arrow works the same as the NEXT pushbutton.
P.SCAN (Preset Scan)
Press this button to listen to the tracks on all of the CDs in random, rather than sequential, order. RDM will appear on the display. Press this button again to turn off random play.
AM/FM
Press this button to listen to the radio when a cassette tape or a CD is playing. The inactive tape or CD will remain safely inside the radio for future listening.
TAPE AUX (Auxiliary)
Press this button to play a CD when listening to the radio. Press this button to switch between playing a tape in the cassette tape player and playing a CD in the trunk-mounted CD changer, if both are loaded.
1 PREV (Previous)
2 RDM (Random)
Press this pushbutton to play the CDs in random, rather than sequential, order. RDM will appear on the display. Press this pushbutton again to turn off random play.
3 NEXT
REV 4 (Reverse)
Press and hold this pushbutton to quickly reverse within a track. Release this pushbutton to play the passage. The elapsed time of the track will appear on the display.
5
FWD 6 (Forward)
Press and hold this pushbutton to quickly advance within a track. Release this pushbutton to play the passage. The elapsed time of the track will appear on the display.
RECALL
SEEK
AM/FM
Press this button to listen to the radio when a CD is playing. The inactive CD will remain safely inside the radio for future listening.
CD AUX (Auxiliary)
Press this button to play a CD when listening to the radio. Press this button to switch between playing a CD in the CD player and playing a CD in the CD changer, if both are loaded.
