hi/low beams
hi/low beams
Thanks to all for the useful information. I will be changing the stock bulbs out as soon as the weather warms up. I also have to change a gear in the drivers side light. I will be going to a brass gear. Thanks again.
Jeff T. (03-19-2018)
Denny , I just replaced my headlight gears with the brass ones ( 2 complete kits ). I got the best deal from Amazon on them for $93.00 and free shipping ! It's best to change both of them an you'll never have to worry with them anymore .
Denny Kohlman (03-24-2018)
I got a brass kit from Rodney Dickman; installation was actually quite easy. Only real problem I had was with the headlight assembly out I could see how melted/burnt the running/marker light housings were along with the bulb sockets.
Decided it was best to replace the light housings at same time and go to LEDs. So cost me an additional $160 or so for new sockets and light housings.
Received 19,302 Likes
'20-'21-'22-'23-'24
Good luck with the gear replacement - good choice going with the brass gears.
Pro Mechanic
Yep, been there, done that...did both gears and no issues since...
Pro Mechanic
