Key Hole Covers are Back!!!
Our original design uses OEM paint (we can match ALL GM Vette Colors) that will match your car perfect.
- Built to Last - Nickel Plated neodymium magnets custom cut for the Corvette
- High Quality
- OEM Paint for a perfect finish (primer, basecoat, and clearcoat)
- Easy to install and remove.
Give your car that sleek look of keyless entry. Our Patent-Pending design is perfectly color-matched to any factory paint available from 1997-2004.
The Invisi-Lock is made from high quality, nickel plated magnets which snap into place without any modifications and can be removed just as easily if your key fob stops working.
Our Key Lock covers come in any factory color. The paint is from GM, so color match is as perfect as OEM.
Once installed, our covers are made to last and withstand the abuse of daily driving. They can be removed if the time comes that your keyless entry stops working. Our covers also protect your locks from dirt and moisture.
You can order right here....
http://www.southerncarparts.com/corv...rs-p-3379.html
Thanks,
Dave
- High Quality
