I have several sets of sae and mm wrenches up to 15/16 and 19mm.
what wrenches do i need above that? i know one i need is a 24 mm for the tie rod bolt and seems like the rear wheel hub is a 40 mm socket? what others do i need for my tool box. i could just try and find a whole set of big wrenches but don't seem there would be that many you really need.
I would assume most of us have the "standard" set. When I need something above and beyond I go to HF/Pep Boys for the one size unless I know it will get plenty of use.
I have what some call a Ford wrench, the small one ( 9“)will go upto near 4”, but will adjust Down to near paper thickness , once adjusted on something when removed will not fit until it is opened up and readjusted , put a pipe for leverage or hit with a hammer. Used it on hydraulice hose in the aircraft industry when changed adapters and end fittings.
also have a Neiko pro 1/2 drive torque wrench, seen them cheap, lifting a gallon of milk seems harder than torquing to 100 ft/lbs
Reason: Additional info
It seems that sometimes no matter how many sockets, wrenches, etc, you have, the one you need is the one you don't have. Which is why I tell my wife every time I get something new: "It's better to have it and not need it than need it and not have it." Plus it makes you popular with your friends who call to borrow stuff.
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
the rear spring has like a 21mm up top. sunex has a set of angle wrenches for $44 on ebay something like 20,21,22,23,24,25, and then another set for $44 sizes 26,27,28,29,30.31,32
thats what i bought to complete my wrench set above 19, it had all the sizes i was missing
For the odd or large size tools that are used very infrequently, I just borrow them from AutoZone. My deposit is refunded when I return the tool and I didn't invest the money on a tool that I use only once or twice.
I have a massive breaker bar set that ranges from 28mm up to 50MM. It weighs about 50 pounds and I've used it exactly 3 times. Worth every penny because I'm a child and I can't resist having these things if I need them once.
Good advice - I think O’Reilly’s also loans out tools.
