Identifying LS1 vs LS6 Intake/Heads
Old Apr 3, 2018 | 07:03 PM
Chris Draper's Avatar
Chris Draper
From: Gilbert, Arizona Currently Own: 1998 Coupe YouTube: My Corvette Life
Default Identifying LS1 vs LS6 Intake/Heads
I am slowly uncovering the secrets of the 1998 C5 I purchased in Oct of 2017. I recently discovered that the car has C6 Z06 shocks and C6 Z51 sway bars.
The engine does have a big cam. But that is all the info the previous owner knew. It was installed by the owner before him and it is an older build. The guy before me had it for 7 years. I'm curious if they upgraded the heads and intake.
Without disassembling everything, are there any visual markings on the heads that would ID them? And where would I look?
Same question for the intake. How do you tell the difference between the LS1/LS6 intake?
Old Apr 3, 2018 | 07:40 PM
1999corvettels1's Avatar
1999corvettels1
Look for 243 stamped on head.
Old Apr 3, 2018 | 08:14 PM
Chris Draper
Where would that be located, and is that LS1 or 6?
Old Apr 3, 2018 | 08:18 PM
WetMountainMan's Avatar
WetMountainMan
Old Apr 3, 2018 | 08:31 PM
grantv's Avatar
grantv
243 is LS6 heads
Go to passenger side, look at right front of head
Old Apr 3, 2018 | 09:12 PM
MikeG37's Avatar
MikeG37
LS6, front corner of passenger side head
LS1, the same spot is just blank.
I think the LS1's head # is on the firewall end of the head.
Old Apr 4, 2018 | 12:11 AM
Crosis's Avatar
Crosis
mine has 241 stamped in the same place as the ls6 head. Front of passenger side head.
Old Apr 4, 2018 | 11:01 AM
WetMountainMan
What is the second braided hose on the left side, coming through the middle if the rail cover?
Mine only has one at the rear (2002 Base Vert, LS1).
BTW - I checked my engine and it is stamped "241".
Old Apr 4, 2018 | 11:11 AM
1997 C5's Avatar
1997 C5
I have 97 C5 on my Heads on passenger side top front is also blank & very shiny almost looks like it was shaved off. I looked on driver side it's 806 heads
Mine all stock when I bought ti last Nov.
Old Apr 4, 2018 | 11:37 AM
Carl Timonen's Avatar
Carl Timonen
https://www.corvetteforum.com/forums...need-info.html
Old Apr 4, 2018 | 01:35 PM
Chris Draper
1997-98 had 2 fuel lines.
Old Apr 4, 2018 | 01:51 PM
Smoken1's Avatar
Smoken1
IIRC, 1 is a fuel line and the other is the return line on the 97-98 vettes
Old Apr 4, 2018 | 05:16 PM
Chris Draper
As for the intake manifold: here is what I found from a bit of research.
If the manifold is off the block:
-LS1 intake has a hump on the bottom.
-LS6 intake is flat on the bottom.
If the manifold is installed on the block:
-LS1 intake you can fit your finger between the intake and the block.
-LS6 intake you can NOT fit your finger between the intake and the block.
Part Numbers:
#12561269 or 12560688 (LS1 F-Bodies 1998-00)
This is the LS1 intake found on all LS1 F-Bodies from ’98-’00. It clearly has an EGR provision just behind the air inlet. The bottom of the intake is curved.
#88894095, 12557846, 12556333 (LS1 1997-00 Corvettes)
Here is the part number for the deceptive ’97-’00 LS1 Corvette intake manifold. It does not have EGR, and when installed, looks identical to the LS6 intake. The bottom of the intake is curved.
#88894339, 12573572, 12561184, 88890524, 88890523. 88894339
This part number is for the LS6 manifold found on all LS1-powered ’01 and ’02 Camaros and Firebirds, ’01-’04 Corvettes and Z06s, ’04-’05 CTS-V, and the ’04 GTO.
Let me know if there is anything here that is inaccurate.
Old Apr 4, 2018 | 07:44 PM
grantv's Avatar
grantv
What casting are your heads?
Old Apr 4, 2018 | 09:10 PM
WetMountainMan
Where is the intake manifold number?
Old Apr 5, 2018 | 02:00 AM
C5 Kirkland's Avatar
C5 Kirkland
"It's got a big cam" without telling you anything else about the engine is not good for your piece of mind or your engine, and without major disassembly, you will have no idea what the PO did or didn't install.
Old Apr 5, 2018 | 01:02 PM
jasper1978's Avatar
jasper1978
I was told my 2001 vert, had high flow heads, but just looked and its got the 241 stamp, so that means stock heads. Doesnt it?
To Identifying LS1 vs LS6 Intake/Heads
Old Apr 5, 2018 | 01:06 PM
C5 Kirkland
They could have ported your stock 241 heads, but again, without pulling the heads, you won't know.
Old Apr 5, 2018 | 06:05 PM
Chris Draper
Front driver's side.
Old Apr 6, 2018 | 01:55 PM
WetMountainMan
I found that I have a #12573572 intake, so L6 intake and heads on my 2002 Base Vert.
