Power duct problem?
Old Apr 25, 2018 | 12:29 PM
chasboy's Avatar
chasboy
Oldtimer
Default Power duct problem?
The power duct from my older Halltech intake contacts the hood insulator, and it's possible even pushes the hood up slightly. (never measured, but it's out right now and I can check after the rain...again.
has any one had a similar problem? Is it possible to modify the radiator support or the duct itself to get enough clearance?
Thanks all.
Old Apr 26, 2018 | 10:03 AM
Gordy M's Avatar
Gordy M
That is a very common problem for a number of aftermarket ducts. The only solutions I have heard of involve heating and softening the plastic and reshaping it, filing some of the plastic off to make it fit and going back to the stock ducting. Regardless of Mfgrs claims, the do nothing to increase power to a stock C5 Corvette. The non=programmable software in the PCM is set for the stock ducting going thru the accordion bellows. The amount ofair information going thru the MAF is sent to the PCM, if the air going thru the duct and bellows is different (than stock), overly rich or lean conditions can exist. While the PCM can make some limited adjustments, over time, to changes often it never compensates enough. Also, often the smooth bellows are over tightened and the pinched results lets un-metered air into the engine.
Old Apr 26, 2018 | 10:34 AM
chasboy's Avatar
chasboy
Oldtimer
Thanks Gordy, I considered using heat, and now that it seems that this is not uncommon I may pursue it to a limited extent. I already removed some material from the depression in the radiator support and the contact area of the duct. I’m sure a change of 1/8”, from what you are telling me, won’t make that much of a difference.
Old Apr 26, 2018 | 02:24 PM
jjc508520's Avatar
jjc508520
Originally Posted by chasboy
The power duct from my older Halltech intake contacts the hood insulator, and it's possible even pushes the hood up slightly. Has any one had a similar problem?
My hood insulator has a slice right through it from the clamp on my duct - doesn't seem to be causing any issues on the other side though. Have just been too lazy to address it. I checked - and the C5 hood insulator is available from the dealer for something like $180 - if/when I replace it then I'll look at filing it down....
Old Apr 26, 2018 | 06:28 PM
chasboy's Avatar
chasboy
Oldtimer
I used heat to adjust the area that leans over the radiator support. The hood <seems> to sit lower, but I won’t know till I drive it for awhile.
Old Apr 26, 2018 | 09:50 PM
baddboyz03's Avatar
baddboyz03
how about just removing the hood insulator, you dont need it.
then get the underside of hood painted to match.
much better!
Old Apr 26, 2018 | 09:57 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I used heat for my Vararam, easy !!!!
Old Apr 26, 2018 | 11:48 PM
chasboy's Avatar
chasboy
Oldtimer
I did some artwork on it and I like having it on. I think the heat may have worked ok.
Old Apr 27, 2018 | 05:50 AM
LoneStarLizzard's Avatar
LoneStarLizzard
I bought and installed a new DeWitts dual core radiator - they're "low profile" - and Spal fans for only $1,300 and that stopped the dreaded "hood insulator indention" problem my K&N unit was causing.
Full disclosure: I had to buy a new radiator to resolve an overheating problem with my FI set-up; fixing the insulator issue was serendipity.
The Lizzard
To Power duct problem?
