Battery Tender
Old Apr 29, 2018 | 12:39 PM
jimsragtop's Avatar
jimsragtop
Default Battery Tender
Any problems using my battery tender that came with my 2016 Vette on my 2003?
Old Apr 29, 2018 | 12:41 PM
knewblewkorvette's Avatar
knewblewkorvette
No problem, it should work with any 12 volt battery
Old Apr 29, 2018 | 01:51 PM
c4cruiser's Avatar
c4cruiser
What tender did you get with the car?? I have two Deltran Battery Tenders and they work great on both my C5 and C4. Over the winter I leave them connected to the cars so that the batteries are always fully charged and ready to go.
I installed the cable ends that have ring terminals so all I have to do is to connect the cable from the Tender to the car. Don't even have to open the hood
Old Apr 29, 2018 | 02:21 PM
I do not think you would have any problems using that Battery Tender on your C5.
Old Apr 29, 2018 | 02:49 PM
DirtRoad's Avatar
DirtRoad
How did you run the wires on the C5?
Old Apr 29, 2018 | 03:17 PM
glbeauchamp's Avatar
glbeauchamp
I'm curious about that too.
Old Apr 29, 2018 | 04:23 PM
jimsragtop's Avatar
jimsragtop
Thanks all, now I have a battery drain problem, will be looking into that this weekend. Install a new red top and battery was dead in 2 days.
Old Apr 29, 2018 | 04:30 PM
c4cruiser's Avatar
c4cruiser
I attached the ground wire on the tender end with the ring terminal to the negative battery cable. That battery terminal had been replaced at some point so all that was necessary was to remove the cable clamp, place the ring terminal on the clamp bolt and re-connect the cable to the battery.
For the positive side, I attached the ring terminal to the B+ post at the underhood fuse box. I ran the cable up to the corner of the hood and just let it sit there. It came with a molded cover so it can't get wet or damaged.
Old Apr 29, 2018 | 06:46 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i use the cigarette lighter
Old Apr 29, 2018 | 07:15 PM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
Same here.
Old Apr 30, 2018 | 01:03 AM
Crosis's Avatar
Crosis
I have a yellow top and it has both side and top terminals. I connected the tender to the top terminals and run the connector from under the hood and cowl.
Old Apr 30, 2018 | 01:35 AM
groovyjay's Avatar
groovyjay
My favorite Elvis song always was the ”Love me battery tender”...
To Battery Tender
