Nav, camera.
Old May 2, 2018 | 10:11 AM
jackthelad's Avatar
jackthelad
Default Nav, camera.
Been AWOL here for a while - other priorities. What's the current thinking on the best nav/rear camera/head unit and replacement console setup?
I have that whole area in pieces at the moment to replace the hazard switch. Whoever the dimwit was who decided to bury a likely-to-fail item (the flasher unit) in the depths of the dash pad requiring removal of everything from the center console to all the dash area padding and trim, should be condemned to spend eternity changing them. BUT the repair manual instructions are precise and accurate, so it's just a take your time and don't break any plastic bits task
I heard DD Mods had given up on Vettes, so I'm looking for options and recommendations.
Thanks.
Old May 2, 2018 | 10:22 AM
chasboy's Avatar
chasboy
Oldtimer
Vettenuts makes the DD size bezel. I have a Kenwood 9903 (from DDmods) with Apple Car play and love it. Modernizes the driving experience beyond belief, just from the NAV perspective. I also have the KW backup camera and it’s great as well.
DDMods provided a ‘better’ wiring harness, so I only had to deal with a single wire splice.
Old May 2, 2018 | 10:44 AM
dbgoodwin's Avatar
dbgoodwin
Why didn't you just install a hyperflash harness? Let's you install LED's and eliminates the problem of the failing hazard switch without having to remove anything but the four screws that hold the panel under the steering wheel on.
As for the double din: vettenuts and pioneer acic5200nex here
Old May 2, 2018 | 11:10 AM
mrlmd's Avatar
mrlmd
There's more than one way to replace the hazard switch, and thanks to finding it on this site, I replaced mine a few years ago in about 15 min. by sneaking my arm up underneath the console, only having to remove the knee bolster underneath the steering column. Another repair is to replace the flasher with a new one, leaving it hidden under the dash by that bolster. Both of these methods are on the forum somewhere, I don't have time to find them now. Why work any harder than you have to?
Old May 2, 2018 | 01:24 PM
chasboy's Avatar
chasboy
Oldtimer
Originally Posted by 8VETTE7
I purchased the modified console from DD some years back and have a Kenwood head unit that supports 2 cameras and built in Nav and also Apple Car Play and the Android equivalent. The Nav unit does NOT support voice activation which make it just OK in my opinion. Might rethink the built in Nav if I had to do it over again. My iPhone does support voice activation for Maps but perhaps lacks some of the other (Garmin) Nav features. I absolutely love the rear and front facing cameras! Haven't bumped into a curb while pulling into a parking spot since installation. When backing up the Vert it is much easier to see what is behind you with the rear camera. My 0.02 cents.....
Dennis steered me away from the one with the built in Nav. Having Siri available for things other than nav is great.
Old May 2, 2018 | 01:45 PM
dbgoodwin's Avatar
dbgoodwin
kinda confused here.. mine has Siri and built in nav.
Old May 2, 2018 | 01:46 PM
chasboy's Avatar
chasboy
Oldtimer
I have the 9903, which Dennis told me was the newest one at that time.
Old May 2, 2018 | 02:59 PM
dbgoodwin's Avatar
dbgoodwin
but why would having build in nav take away from having Siri? Mine is the avic5200nex from pioneer by the way
Old May 2, 2018 | 03:14 PM
jackthelad's Avatar
jackthelad
Don't know how you could do that. To release the tabs that held the switch in took a hefty push using two screwdrivers, one on each side, then someone to actually yank the switch out of its opening. And without dismantling you cannot even access one of the tabs.
Then of course, there is no way to get your arm up there as the area is completely blocked off by the AC air distribution system and the radio & AC head unit.
Since the flasher is the hazard switch, if you leave it under the dash you don't have a legal hazard switch, plus of course the only thing that holds the switch button in place is the plastic trim and the fact that the hazard switch is correctly fitted into the molding behind the button.
Old May 2, 2018 | 03:24 PM
jackthelad's Avatar
jackthelad
Nav and cameras are my priority. No interest in Siri. My "other" car has excellent nav and AV (9" screen), plus rear camera - now a legal requirement on all new cars, BTW.
Since DD are no more, is anyone else putting any kind of package together?
Old May 2, 2018 | 06:03 PM
Originally Posted by dbgoodwin
[left]Why didn't you just install a hyperflash harness? Let's you install LED's and eliminates the problem of the failing hazard switch without having to remove anything but the four screws that hold the panel under the steering wheel on.
Not a hard job to do at all.
Old May 2, 2018 | 07:47 PM
chasboy's Avatar
chasboy
Oldtimer
Originally Posted by [COLOR="Blue"
dbgoodwin;1597119318]
AND 8vette7
[/COLOR]:
Guys, when I first called to order, Dennis told me that he felt the 9903, which was a new model was better than the previous for a few reasons. As for built-in NAV, he felt that since Apple products are constantly upgraded, the CarPlay would enable me to have the latest maps and Siri-enhancements that Apple offered. The other thing I remember him stating was that the new touchscreen technology on that model was a big improvement over previous. That's all I can remember.
I don't know if the built in NAV unit, that also has CarPlay does take away from Siri, but perhaps Siri has more functions due to the newer unit?
Currently Siri does maps, phone, messages-send/receive, music, weather, location and others I can't remember right now.
I'm VERY aware of Apple maps limitations. I've written them that the "concept' of someone having more than one destination in a route is not a far out idea. I have other map programs that allow me to plan multiple stops. Most of the time, in the car, Siri's navigation is fine.
Old May 5, 2018 | 11:08 PM
jackthelad's Avatar
jackthelad
And how is a hypeflash harness going to fix a failed hazard switch exactly???
The OEM lasted from 1997 to 2018, so I don't expect it to fail again anytime soon.
To Nav, camera.
