Lubricating the door hinges
Old May 3, 2018 | 02:59 PM
jjc508520's Avatar
jjc508520
Default Lubricating the door hinges
What's the best way to do this? I keep shooting silicone spray on them - and besides being messy I don't really think its the right stuff to use...
Old May 3, 2018 | 03:21 PM
Alexander K's Avatar
Alexander K
lithium aerosol grease for squeeks. If you feel it catching the bushing has been damaged and needs to be replaced.
Old May 3, 2018 | 03:52 PM
vetintheblood's Avatar
vetintheblood
From: Beavercreek Ohio Currently own: 1958 Silver Blue Corvette & 1969 Riverside Gold Corvette Coupe
2025 C1 of the Year - Unmodified Finalist
wd-40
Old May 3, 2018 | 04:34 PM
Velocity_Vette's Avatar
Velocity_Vette
I spray a white lithium grease on them maybe yearly at the most. It does leave a residue but any excess can be wiped off.
While WD-40 is a good penetrant and can drive out moisture it's not ideal for long term lubrication. A shot of WD-40 to clean or drive out moisture should still be followed with a good grease or similar lubricant.
Old May 3, 2018 | 10:35 PM
Use some lithium grease for a more long term solution.
Old May 4, 2018 | 08:14 AM
runner140*'s Avatar
runner140*
Me too. Doors and hood.
Old May 4, 2018 | 10:57 AM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Wilson Combat synthetic grease for me. Comes in a syringe, so it's easy to be precise, and the stuff lasts forever, and is silky-smooth.
Old May 4, 2018 | 08:11 PM
jjc508520's Avatar
jjc508520
Thanks for the suggestions!
Old May 4, 2018 | 09:12 PM
JETZ's Avatar
JETZ
‘kY’ Racing, Stops all little squeaks, and eliminates friction...
frank
Old May 5, 2018 | 12:37 AM
MikeG37's Avatar
MikeG37
I got turned on to this to quiet my popping rear hubs. Since then I've been using it on everything that moves, pretty impressive stuff. It works just as good, and may last even longer than lithium grease.
Old May 5, 2018 | 05:35 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Clean the door jams/ hinges and lube at the same time.
Old May 6, 2018 | 10:20 AM
momo20's Avatar
momo20
Originally Posted by vetintheblood
wd-40
wd-40 is one of the worst lube's one can use on moving part's...why well i own a glass shop and always working on window and door's for my business we don't even use wd-40...it oil based and it will work great right away but over a week it will be covered in dust and dirt and be worse then before...i prefer to use pledge lemon spray on moving part's its wax based dirt and dust avoid it and works amazing...
Old May 6, 2018 | 12:56 PM
SG Lou's Avatar
SG Lou
Ditto
Old May 6, 2018 | 04:21 PM
deejbee's Avatar
deejbee
We used to use Wurth lithium grease in the bodyshop I used to work in.
As for WD40, "WD stands for "water displacing" and its main use is as a solvent or rust dissolver. The lubricant-like properties of WD-40 come not from the substance itself, but from dissolving components. And the effect doesn't last."
(not that everything in the internet is right, but I would never use WD40 on door hinges)
Old Mar 20, 2019 | 02:34 PM
Molly815's Avatar
Molly815
mine is popping each time i open or close,, you comment about replacing the bushing sounds like what i need to do to correct my problem. question is how do you just replace this bushing looks like it is a pressed on piece of the hinge itself?
Old Mar 20, 2019 | 03:37 PM
Josephu's Avatar
Josephu
Ya know....back in the day,, and I mean way back,,,before they had all these different detail sprays. .we used to use lemon pledge to detail out paint jobs. Maybe thats why all these sprays each have a different arouma. Bunch of copy cats.
Old Mar 20, 2019 | 07:14 PM
91LSMAN's Avatar
91LSMAN
When I had this happening it got so bad that sometimes the passenger side door was hard to close. I had the hinges replaced. Problem solved. I bought the hinges online.
To Lubricating the door hinges
Old Mar 22, 2019 | 07:03 PM
Molly815's Avatar
Molly815
how do you replace the bushing by itself? doesnt the entire hinge have to be replaced?
Old Mar 22, 2019 | 08:20 PM
StickTail's Avatar
StickTail
I am also interested. What part # do I need?
Old Mar 22, 2019 | 11:23 PM
Corvette#2's Avatar
Corvette#2
I used AC Delco PTFE grease once a year. Put a newspaper behind the hinges to catch overspray.
