[Z06] Engine cleaning cloth
Old May 6, 2018 | 12:19 PM
Mayor's Avatar
Mayor
Default Engine cleaning cloth
Greetings,
I'm just wondering if there is some type of engine cleaning cloth available. I want to keep the engine free of dirt, etc. without having to use water. Thanks in advance
Old May 6, 2018 | 01:42 PM
calguy's Avatar
calguy
Originally Posted by Mayor
Greetings,
I don't think there is any special type of cloth to use for the engine bay.
I clean the engine bay about every two weeks, and all it takes is a soft cloth, and some spray windex.
If the engine bay has not been cleaned before, or for a long time, I would use simple green diluted, and then rinse with a rag that is wet.
Bob.
Old May 6, 2018 | 01:53 PM
rrwirsi's Avatar
rrwirsi
Bob.
Another cheaper cleaning agent then Simple Green is using Dawn dish soap.
Old May 6, 2018 | 02:20 PM
Dbl_D718's Avatar
Dbl_D718
I like to spray an older microfiber towel with a spray-wash bottle (like Meguiar's Wash & Wax Anywhere) and just wipe things down. Just hitting the big plastic surfaces like this every once in a while keeps it clean enough to impress the cars and coffee crowd.
Once a microfiber gets demoted to engine cleaning, it doesn't get used on paint anymore.
Old May 6, 2018 | 06:37 PM
Mickeyrx70's Avatar
Mickeyrx70
That’s what I do every couple of weeks and it works just fine. The key is once you get it clean, don’t let it get dirty again.
Old May 6, 2018 | 10:33 PM
If you have grease or oil that needs to be removed, Simple Green works well. If it is just dusty, I use a Swiffer duster and then use an Absorber (synthetic chamois) to wipe the components down. You could also use an air compressor with a blower nozzle on it and get rid of some of the dust first.
Old May 7, 2018 | 08:01 AM
runner140*'s Avatar
runner140*
Greetings,
I use rolls of shop/blue paper towels vs cloth. They are cheap/Walmart and disposable.
Old May 12, 2018 | 09:14 AM
Spaceme1117's Avatar
Spaceme1117
Nothing wrong with using water to clean the engine bay.
Here is a good video on how to safely and thoroughly clean your engine bay:
To Engine cleaning cloth
