Trans fittings (photos wanted)
Here's a picture of the end result. I've never had a radiator installation be so complicated. The connections are very secure and no leakage.
The red fitting is an inverted flare to mate with the fitting in the radiator. The blue fitting secures the flared pipe to the red fitting.
jrprich (09-09-2018)
On the 4runner forum there's a lot of chatter about "pink milkshake" that results when the radiator fails and the anti-freeze gets into the trans. Like most other hi-milers - I bypassed it and now run an aux cooler mounted in front of the radiator....
Solution??
Ok, while I wait for a 1997-2000 photo, I will pose this question to the 2001-2004 group.
Has anyone tried to take this fitting apart?
It looks like there is a nut, that holds the tube in, and the body. I colored the fitting to show my theory. I guess you would have to destroy the body to get them apart since it has no wrench flats to hold it.
Later C6 they switched to the retaining clip
So did anyone be ever figure out if this purple fitting can be separated or not? Is it actually a quick disconnect? If so, what QD tool is the one for the job? Thanks!
google OTC 6611,, i know because when i tried to unscrew the fitting the threads came out of my radiator, had to get a new one
You are right! Sorry to anyone that sent me anything. I shut off the PM now. It should be noted that I sold the business and retired. I still frequent the CF for advise but www.dewitts.com is the place to go for specific product updates, pricing, and delivery questions.
I had to cut off the factory fittings and then use AN fittings to make a proper connection to the new radiator. For the AN fittings to work, I had to flare the pipe. End result? Secure trans lines with NO leakage.
The blue nut pulls the flared pipe up against the red fitting.
