Differential carrier assembly?
Old May 17, 2018 | 12:13 AM
envisi0n91's Avatar
envisi0n91
Default Differential carrier assembly?
When I look at part number 12572683 on gmpartsdirect.com I see it says "differential carrier assembly." Does this include the entire rear end and is just a direct replacement or is it just the housing without the gears?
Old May 17, 2018 | 12:17 AM
oneandgone's Avatar
oneandgone
That should be a complete assembly. You should be able to call and confirm that in the am.
