Newbie question here. I would like to buy an 02z that is located in Washington state. It's procharged with Kooks long tube headers, Kooks mid pipe with cats and stock TTI exhaust. The procharger has a CARB number so it's no problem but the Kooks headers and mid pipe will not pass the visual part of the smog test. I've read posts in other forums from from folks who have had their cars pass smog testing with the identical set-up but would rather get the car right with Ca requirements. Any ideas? I have called a dealership in Rio Vista to get an idea of the cost to put it back to stock and I'm waiting to hear from them. Anyone have a recomendation on a good performance shop in the bay area for this kind of work? Should I trust a local muffler shop? The headers and mid pipe are fairly new-do they have any resale value? And one more question. If I do replace the Kooks parts with stock parts, and considering the procharger (5-6lbs boost) will I be faced with any issues (I'm assuming that the stock headers will be more restrictive).
Thanks!
Thanks!
Many in California have put the C6 Z06 exhaust manifolds on their Z06s.
While they do not flow as well as the long tubes, they are a good compromise with a little better flow than the stock C5 Z06.
