Snake in The Vette! (or a mouse)
St. Jude Donor '10
Getting an awful odor of a dead mouse or snake when the vent air is turned on. Looked all over in the engine compartment but couldn't see anything. I assume it's inside the air duct somewhere.
Do I wait until the damn thing is decomposed an no longer stinky or is there a way to see and remove it?
TIA
TIA
It’s probably just mildew. Buy a spray can of Lysol disinfectant and spray it into the cowl air intake. Have your a/c on full and turn off the recirculation. Make sure your windows are open.
My Ford Edge has this problem from time to time. It smells like a locker room and this fixes it.
Received 19,309 Likes
'20-'21-'22-'23-'24
If it is not just mildew and is a dead critter, I would make it a point to get it out soon. Not sure if there is an easy way to see exactly what it is and where it is located.
Running Guns & Moonshine
It may be worth pulling the fan out of the passenger foot well and checking it. When I bought my car, it had sat in a garage for a few years and a mouse had camped in there one winter and died. No odor issue by the time I bought the car. Just an off-balance fan whirling its corpse and a few nuts in circles like a blender.
Edit: you will also want to check / empty your 3 bladders on the driver side up inside the fender well. If a critter was in there and died, it brought food, and in my case the bladders were clogged with nuts.
chiefbob (05-25-2018)
Received 3,867 Likes
2015 C5 of the Year Winner
^^^^this^^^^ I bet whatever it is is most likely stuck in the fan squirrel cage or close by it.
St. Jude Donor '10
I'll check that squirrel cage. Thanks.
