Xpipe Comparison
Old Jun 8, 2018 | 09:21 AM
striper's Avatar
striper
And a painted clean floor, plus A/C or heat and cable TV.
Old Jun 8, 2018 | 09:41 AM
chasboy's Avatar
chasboy
Oldtimer
Lol!! Thanks Bud. I’ll keep you in mind!
Old Jun 8, 2018 | 11:51 AM
v6turbo87's Avatar
v6turbo87
Originally Posted by chasboy
AND made a cleaner hole?
Couple of things,
I have a bid on a new Borla X now. Does the Borla come with the holes for the oxygen sensors?
I really want to do this at home by myself but I get a little claustrophobic under the car, even if it’s on my very sturdy ramps. Any advice on getting it a bit higher? With jacks stands I’m ok with the room, but I then get nervous about them tipping over.
From what I see from pix online, the only difference between the Borla and Corsa is the Borla is not as ‘shiny’(?) as the Corsa and $100 less.
Thanks gang.
The O2 sensors not are located in the X pipe. You cut the stock H pipe downstream of the O2 sensors.
Get a low profile long reach (24") floor jack from Harbor Freight.
Also get 6 ton jack stands. They a much taller than lower capacity jack stands.
Old Jun 10, 2018 | 08:26 AM
steig's Avatar
steig
Thanks, I don’t mind the popping, but the motorboat ‘chuffing’ is getting old.
I’ll be reading those instructions a few more times!!!
I agree, didnt like the motorboating sound either.
Installed Borla X-Pipe, motorboating sound gone.
Old Jun 10, 2018 | 09:59 AM
chasboy's Avatar
chasboy
Oldtimer
Ordered the Borla from Chip at CCA last nite.
Old Jun 10, 2018 | 02:12 PM
Rlb2002vette's Avatar
Rlb2002vette
Just curious? What if you did something like the exhaust mod where the H pipe meets with a 2 50" crossover pipe?
Old Jun 10, 2018 | 05:36 PM
chasboy's Avatar
chasboy
Oldtimer
did you mean 2 1/2" pipe?
If so, I think there would be a turbulence issue. I'm only acquainted with flow terms through a piece of tubing, a real engineer would be better for this.
Old Jun 10, 2018 | 09:22 PM
striper's Avatar
striper
An H-pipe of the correct 2.5" diameter would probably increase the low rpm rumble.
Old Jun 10, 2018 | 10:01 PM
Rlb2002vette
Ty I was just wondering about the outcome cutting the crossover hole to 2.50"
Old Jun 10, 2018 | 10:10 PM
chasboy's Avatar
chasboy
Oldtimer
I’m thinking the turbulence caused by the larger opening might cause flow restrictions.
