Possibly buying 2004 model
144,400 miles
car had 2 owners.
Pa. And Trenton, Michigan
Both salt road states.
Should I get it up on a hoist to check the under side?
Thank you in advance.
Ken
As for buying a car from a state that applies salt on the roads, a lot depends on whether the owner drove the car during the winter and how well the owner kept the car clean if it was driven. I woukdn’t Discount it just for that reason but it does suggest a close inspection.
Trust no one. Verify for yourself.
With 144K miles, there is a good chance it might have seen salt.
Do check everything, targo top seals, door seals, belts, hoses, tires, brake pads, etc. If the price is right and it's what you want, buy that sucker and drive it. ;-)
But here is what I did miss:
1st it needed a new battery
2nd it is a 6M and it turned out that it had the infamous steering column issue (easily fixed...thanks to information on this forum)
3rd a broken radio tuning **** (cheap fix, Amazon)
4th driver's seat cushion (another known issue...they cave in...and if you don't know how the seat is supposed to feel, I did not, this is easy to miss)
Once up on a lift (when I replaced my tires), I got a very good look at the undercarriage. No sign of any leaks (this is actually one of the main reasons to get this car up on a lift). I was amazed it was every bit as good as I thought. It showed some slight spotting on the frame, but is for all intents and purposes, clean as a whistle.
So get it up on a lift...but in addition read the stickies, there are lots of other things you should examine, not just the salt issue. But don't let those stickies scare you off, these are fantastic cars.
You are over thinking this imo ..
I have 122k miles on my daily driver c6 in all types of weather and the car on the lift looks fabulous..
If you want to put the car on the lift and look around it’s never a bad idea ....to have a professional look at any vehicle makes sense so you don’t have any surprises...
But if the cars under 15 grand which I think it probably is....and the owner looks to be a standup caring owner and he has service records....I’d probably just buy it...if it looks good..
Weather corrosion is pretty much a non event on these cars built from 1997 onward.
GM built these cars to be all weather vehicles.
Couldn’t hurt to put on a lift or get mechanically get checked out as it’s pretty probably 150 dollars which isn’t much and is often suggested as common sense on buying any used vehicle...I’m just being honest...I probably wouldn’t bother...
Jmo
