HVAC Panel LED light replacement question!
Old Jun 11, 2018 | 08:55 PM
chasboy's Avatar
chasboy
Oldtimer
Originally Posted by grasshopper645
Its interesting to here about the leds still dimming, could you elaborate? The stock dimmer is a rheostat and would dim much faster than the original incandescents. I assume it would be completely dim by about the half way mark, wouldn't that look out of wack with the dash display (blacklights)?
I am having a nightmare trying to find the stock incandescents for the DIC cluster. You can get generic ones from ebay but they don't have the blue rubber shield around them. I'm thinking switching to LEDs might just be the easier option..
Also great advise about removing the bulbs from the neo wedge, and then not having to use a resistor!
In certain cases I moved the led to the stock incandescent base.
I mean no disrespect here but why would you want the stock bulbs in the DIC cluster? Dull coloring and brightness. I might have some incandescent leftover you are welcome to.
Old Jun 11, 2018 | 09:28 PM
grasshopper645's Avatar
grasshopper645
Lol none taken mate, your not the first one to ask!
My justification is simply to retain the dimming feature to be the same as the black-lit guage cluster. I didn't want to dim it half way and have the LEDs completely off, and the dash still lit partially.
Although after reading this thread, I think I am changing my mind...
