My wide body build thread
The soft contours of both sets of fenders seem to match well.
I think with a rear 13" wheel, you're asking for trouble, and it may not fit and could encounter clearance issues both on the inside liner, and fender.
I'm running the CC 1" front with the CC 2" rear on a track setup with OEM C6Z wheels, and a 12mm spacer out back and they sit perfect...any larger in the rear even with correct backspacing would put me at the limit with a 13" and you're already losing width since you're running a 1.25" fender. Just my opinion...hate to see you do all this work and find out they don't fit.
I will be shooting a vid later in the week to explain the C5 foot print with flares...hope this helps
wheel. A 11 or 11.5 wheel will fit nicely.
Good luck.
I test fitted the wheels on the car with the stock fenders just to take some more measurements and to see where I stand. While this is not a true indication of how it will look in the end, this fitting has shown a few things: First, this wheel fitment combo is going to be quite "aggressive". I imagine there will be a slight "poke" (is that what they call it these days?) which can be corrected, some what but not fully, by altering my camber settings. Either way, I am ok with the look although I know many see it as "tuner" or "stupid". I make no apologies for it. And second, I think it is going to sit very nicely when it is all said and done.
Anywho, onto some pictures.As you can see, the wheels do protrude past the stock fenders. That goes without saying. How far they go past, however, was a touch more than imagined.
This is a bird's eye of the front wheel. It protrudes past the fender by approximately 1.2". Should look nice with the CC 1" replacements.
This is a bird's eye of the rear wheel. It protrudes past the fender by approximately 1.7". A bit more than the L5-R's may allow but workable. Worst case scenario, I move up to a 2" flare in the rear.
For those who were expressing concern about widening the rear wheels too much, there are almost exactly 3" of clearance to the inner fender, so going to 12" should not be a problem. Here are a few more pics.
That's all for now. Hope to have the wide fenders and quarters test fitted and off to paint in the next two weeks.
