Looks like mine is wobbling,my belt was chirping and made me look. I don’t want a GM so what is a good aftermarket one. Motor is stock with 74,000 miles.
Dayco Powerbond PB1117N. Almost any parts house will have it.
Don't forget the ARP 234-2503 bolt. Right now they are back ordered nation wide so you will have to search for it. They are out there you just have to find one.
Good luck!
Good luck!
You might want to pin it to the crank while you're changing it. PITA job to change the balancer, and someday, you just might want a SC. The pinning is quite easy.
From: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
Good luck!
A local shop that specializes in LS motors told me this particular OEM-style Powerbond unit will fail just like the GM OEM one since it's constructed the same way (with rubber instead of being fully metal). And that there's a different Powerbond "race" balancer which won't ever fail.
Has anyone used this PB1117N Powerbond OEM-style balancer over a long period of time/miles and can comment on how it holds up? I'd rather save the money and get this Powerbond PB1117N OEM style rather than the race version if it's good enough and won't fail.
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
Plenty of guys here are running the PB1117N. I've only had mine on for about a year so far with no issues. My car is about 80% track use and 20% street. It regularly sees red line and and I'm pushing a mild 400rwhp. I know it's not long term use, but I chose PB1117N because of all the good reviews it had over OEM from guys who were in my HP range. Not sure if that helps, but you get the idea.
A buddy of mine was told by andy at A&A that tons of guys run this HB with their blowers, pinned, with good results.
and using the ATI pin kit through the side of the snout...
Any thoughts? i'm eventually going FI but probably just staying 6 rib
the Q/A on that HB have a lot of strange feedback saying it won’t fit kn “stock” corvettes.... I feel that’s vague? Others say it fit on their 99 or 00.
any confirmation this will fit on a 99 FRC?
i can't address that specifically but what i did see is they're an 8 rib pulley and you only use 6...
Local LS shop did the Summit SFI 8 rib on my 99 without issue. They run that balancer on all their motors. So far, so good.
right on! God to hear it. I’m looking to get my FRC relatable enough to take on an 8-9 hour road trip to see my folks and since the live about an hour from the Tip of the Dragons tail I kinda wanna check it out. I think with my Vette being close to 100k miles it’s probably a good idea to change it out first.
