5th Brake Light Flasher
Old Sep 10, 2018 | 05:07 PM
  #41
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Not a problem for me. Honestly, I don’t see why other drivers would be annoyed by that minor issue.
Old Sep 11, 2018 | 07:22 AM
  #42
sirdano's Avatar
sirdano
I got the back off third light. You can also add these to your other four lights. I have been told they are BAF.
Amazon Amazon
Old Nov 12, 2019 | 08:06 AM
  #43
DriveHub's Avatar
DriveHub
1st Gear
QUOTE=Moto One;1597455378]I'v been running a 5th light (was fog/rain now also brake) in-between the pipes, (Hella fog) 5th brake light extremely bright.
what light is that? How did you install it?
Mark.[/QUOTE]
Old Nov 12, 2019 | 09:07 AM
  #44
Gary In NM's Avatar
Gary In NM
Originally Posted by 6speedsteve
I have the Web Electric flasher unit in my car.
http://www.webelectricproducts.com/
Never had anybody say anything bad or neg about this. To install, all you have to do is remove inboard taillight and unplug the unit in. Gary
  #45
Moto One's Avatar
Moto One
It's a Hella fog light, Bosch also has a similar one, I first installed it when I had the car in Europe, I have an oneway Isolator also that will allow it to be turned on constant, and come on with brakes applied.
Amazon Amazon
I attached it using a L bracket to the tub. Simple.
Mark.
Old Nov 14, 2019 | 09:06 PM
  #46
bobgroger's Avatar
bobgroger
I used to be crazed with tailgaters. Then I got a front and rear facing dashcam. Go ahead and hit me, @$$hole! I have your plate and your face if you take off.... And I have noticed I drive a lot better too knowing everything is recorded. I haven't needed it yet, but feel a lot better that it is there.
Old Nov 15, 2019 | 04:24 PM
  #47
jackthelad's Avatar
jackthelad
Couple of days back, I had to drive by the local hospital. An ambulance was a couple of cars ahead. When he put on his brakes, huge incredibly bright high mounted brake lights came on. Think headlight size and round. Obviously LED's as they were "instant" on. I guess where I am going with this is if your four regular oval rears are upgraded to decently high powered LEDs for brake lights, isn't that enough? Those ambulance lights certainly got my attention.
