Safe difference?
Dexos1 Gen 2
The most current dexos1 specification (dexos1 Gen 2) was released in 2015 to provide even higher engine performance and protection, particularly low speed pre-ignition (LSPI) protection in small displacement turbo-charged engines.
GM has developed four new engine tests for this updated specification:
- New General Motors Oxidation & Deposit Test (GMOD) verifies the improved oxidation and deposit control characteristics.
- New Stochastic Pre-ignition Test verifies the added protection for turbocharged engines and pre-ignition concerns.
- New Turbocharger Deposit Test verifies the added protection for turbocharged engines and minimizes deposit formation, which ensures optimal performance during engine life.
- New Aeration Test (bubble control) ensures the air bubbles in the oil dissipate quickly to improve oil performance.
For more information about dexos1 Gen 2, visit: www.centerforqa.com/dexos/
So, is it better than the original Dexos ? Probably. However comments in other writings on the new generation Dexos speak more to the small, turbo engines, as briefly mentioned above.
Additionally, ACDelco Techconnect says:
“Since dexos1 Gen 2 is fully backwards compatible with all pre-2018 model GM vehicles, the previous generation of dexos1 generation will no longer be produced after this full transition.” Nothing there indicating any incompatibility between the two oils; just one has been improved.
Guess if you mix it, you will have Dexos1 Gen 1.5
Going forward you're likely not going to find in stores Dexos standard oil since Dexos 2 has replaced it. Unless you have some sort of power adders and/or accompanying modifications that necessitates running a different type oil for whatever reason your C5 is well within Dexos 2.
. Thanks for the responses.
