[Z06] Intake coupler
Old Jun 24, 2018 | 01:34 PM
egott91's Avatar
egott91
1st Gear
Default Intake coupler
Hey everyone! New to the forums, but not to LS power. If this isn’t the right section for this question, I apologize in advance. However, here is my situation:
I will be doing H/C/I/E on my 03 Z06 this summer and need to find an intake coupled between the air bridge and throttle body. I will be running a SLP blackwing filter to the stock air bridge connected to a NW 102mm TB. I need a coupler from the stock air bridge to the TB. I’m sure there are many of you guys running a 102mm TB and intake, so where have you gotten your couplers? I believe in need a 5” ID X 4” OD that’s 5” long, correct? Or have any of you squashed down the accordion coupler and connected an additional coupler to span the gap to the TB? Any help is appreciated guys, this is the last piece I need in order to be able to start on the swap.
Old Jun 24, 2018 | 10:09 PM
blackmachdown's Avatar
blackmachdown
http://www.siliconeintakes.com/
That should have what you need
