Curb alert install a no-go
Old Jun 30, 2018 | 01:42 PM
jjc508520's Avatar
jjc508520
Default Curb alert install a no-go
I believe I have it correctly installed - but no chirp. I found ‘unused fuse 22’ and also tried a few others but I can’t get a peep out of it???
Old Jun 30, 2018 | 01:53 PM
jjc508520's Avatar
jjc508520
It’s not getting power - I cut off the in-line fuse splice and tapped the bare wire to the battery and got some chips out of it ...
Old Jul 1, 2018 | 12:13 AM
Hope you get it all figured out.
Old Jul 1, 2018 | 09:12 AM
rrwirsi's Avatar
rrwirsi
I used a "Add-A-Circuit" 2-10A by Bussmann found at Auto Zone. I removed a key off fuse that works from the passenger BCM fuse box, put in the 'circuit add' then connected the power to the Curb Alert. I then replace the removed fuse in one of open slots on top of the circuit add. Hope this helps.
ATM Bussmann Add-A Circuit, 2-10A
Old Jul 1, 2018 | 11:25 AM
jjc508520's Avatar
jjc508520
Thanks - I think the one in the kit was no good...
Old Jul 1, 2018 | 12:19 PM
rrwirsi's Avatar
rrwirsi
Could be. I had one go bad on me after install but thankfully still under warranty.
To Curb alert install a no-go
