Best jacking pucks?
Old Jul 11, 2018 | 12:28 PM
v6turbo87's Avatar
v6turbo87
Originally Posted by jrprich
I have similar BMW style pucks that I bought first in 2006 for my 99 and swapped them over to my 03 a year ago. My set was less than $60 but that was off eBay in 06. These four pucks have remained on my two C5s for 12 years and many thousands of miles. I use them all the time and like that they are always there. They are light and all but invisible on the car
Jim
https://www.ebay.com/itm/C5-C6-Corve...AAAOSwmoVaps5o
I got the above pucks from Rock Auto for $32 for a set of 4. Someone posted the PN here on the CF and I jumped on it. Sorry I do not remember from which Year and Model BMW these are from.
Old Jul 11, 2018 | 12:32 PM
v6turbo87's Avatar
v6turbo87
Found the Rock Auto Number,
ÜRO PARTS 51711960752 {#B89301} Info Category: Jack Pad $6.27 each.
https://www.rockauto.com/en/parts/%C...jack+pad,12620
Snap them in and forget about em!
Old Jul 14, 2018 | 12:15 AM
Arodman's Avatar
Arodman
Originally Posted by pjdbm
I made mine with double hockey pucks with a threaded eye bolt. When I raise my car using these, I have two floor jacks and I raise each side a little at a time, then I put ramps or jacks underneath. (depending on the work I am doing)
I did the same thing 4 regular hockey pucks and 2 eye bolts works great for slot less
Old Jul 14, 2018 | 01:01 PM
JHrinsin's Avatar
JHrinsin
Originally Posted by Sabre34
Same here.
Same here as well. They are 90 duro polyurethane and I choose an obnoxious iridescent DOT safe Yellow color so that I could see them and not forget to remove them when the car is back down on the ground
Old Jul 16, 2018 | 05:51 AM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Not sure where I picked up mine , but they are rubber and they work great. Not sure that Aluminum would grip to lift arms or jack as well.
Old Jul 18, 2018 | 11:48 AM
1999corvettels1's Avatar
1999corvettels1
I ended up buying 4 hockey pucks locally, a few years ago I went looking for hockey pucks and couldn't find them at any sporting goods stores.
A few days ago, googled where to buy hockey pucks near me, found a store that is in a building where there are 2 big ice rinks, the black ones were 1.50 each, bought 4.
To jack the car up for a oil change, going to put rhino ramps under front wheels, do I need to drill and add the hardware, or is it safe to jack with the pucks only?
I never plan on leaving them in the framewell.
Or does the eyebolt part help keep it from moving?
Old Jul 18, 2018 | 01:14 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
eyebolt keeps it centered but its not much for metal strength so make sure you are straight on with jack and it can roll freely as the car is lifted
Old Jul 30, 2018 | 02:51 AM
1999corvettels1
Got the jacking pucks made, tried to change oil and jack up one side.
Oops, my floor jack is too tall to go under fiberglass, have to buy a new low profile one.
3.5 minimum lift should be ok?
Old Jul 30, 2018 | 02:53 AM
1999corvettels1
Would this work good?
Old Jul 30, 2018 | 11:26 AM
mrlmd's Avatar
mrlmd
Cheaper than buying a new jack is to drive up on a length of 2X10 to gain another 1 1/2" of height to get your jack underneath.
