How can I fix these wheels?
Old Jul 27, 2018 | 05:50 PM
mrlmd's Avatar
mrlmd
Default How can I fix these wheels?
2000A4 - I assume these stock wheels are chrome plated ? but are pitted or corroded in spots. What can I do to fix this, other than send them off to be spray painted or powder coated? Chrome cleaner does absolutely nothing and I don't want to scratch them up and make them look any worse than they do now. Anything I can do inexpensively, like spray them myself? For any of you that have done this - Does Platidip last long enough on a wheel? And no I do not want to spend a genomous amount of money for new wheels. Thanks for any suggestions.
Old Jul 27, 2018 | 05:56 PM
Chris Draper's Avatar
Chris Draper
From: Gilbert, Arizona Currently Own: 1998 Coupe YouTube: My Corvette Life
They aren't chrome.. Polished aluminum.
Old Jul 27, 2018 | 06:06 PM
1stC599's Avatar
1stC599
Plastidip sounds like your best bet to me. Plastidip lasts for quite a while, there are tons of how to videos and pages of info. It's about your least expensive and least amount of down time for your car. Your other option is taking to a reputable wheel shop and see what they say, but could cost. Hope this helps.
Old Jul 27, 2018 | 06:28 PM
knewblewkorvette's Avatar
knewblewkorvette
Yepper Chris, these are not chrome wheels
Old Jul 27, 2018 | 06:38 PM
gowenfast's Avatar
gowenfast
Finalist 2022 C1 of the Year - Unmodified
2021 C1 of the Year Finalist - Unmodified
2020 C1 of the Year - Unmodified
2018 C1 of Year Finalist
St. Jude Donor '21
What you have is corrosion under the clear coat that was sprayed from the factory on a polished aluminum wheel. There is no way to fix, other than strip off all the clear, re/polish the wheel, and re/clear coat. Not cheap, or easy.
Old Jul 27, 2018 | 06:57 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Send them to Panther Wheels,
http://www.pantherwheels.ca/
Old Jul 27, 2018 | 07:03 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
You're better off bead-blasting them with walnut/fiberglass, and re-polishing from there. (assuming that's the look you want)
C5 4 ME's Avatar
C5 4 ME
My son had a set on his 2002 coupe and one of the rims developed a crack and had to be replaced. Hope this helps
Old Jul 27, 2018 | 07:21 PM
gowenfast's Avatar
gowenfast
St. Jude Donor '21
That would work too...
Old Jul 27, 2018 | 07:30 PM
Bob in Elliot Lake's Avatar
Bob in Elliot Lake
I’ve re finished motorcycle wheels that had the same issue. Aircraft stripper to remove the clear coat, buff & polish until perfect, or until you’re happy with them, then re clear coat. I would guess it would take 5 or 6 hours per wheel once the wheel was sitting on the bench without the tire. I spent more time than that on the bike wheels, but it’s a bike, it was winter, and they "had" to be perfect. LoL
Old Jul 27, 2018 | 07:37 PM
'Shifter's Avatar
'Shifter
NCM Member '09
You could even have them powder-coated in a color of your preference...then they bead-blast them anyway.
Old Jul 27, 2018 | 07:39 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
If they were mine I could make them look like chrome on a Saturday while getting drunk on Budweiser.
*burp*
Old Jul 27, 2018 | 07:46 PM
'Shifter's Avatar
'Shifter
NCM Member '09
*burp*
Well, that's because you have mad polishing skills....
Old Jul 27, 2018 | 07:49 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
^ because I’m a cheapskate I had to learn.
Old Jul 27, 2018 | 11:17 PM
Strip the clear off, and if you want to stick with the OEM look, polish them up and consider putting a clear coat on the wheels. Or, have them powdercoated in just about any finish you want.
Old Jul 28, 2018 | 01:38 AM
z06801's Avatar
z06801
I bet they would be cheaper than you think to drop off to a wheel repair shop to have refinish, and Josh is right a Saturday and a few beers would have them looking tip top
Old Jul 28, 2018 | 12:51 PM
mrlmd's Avatar
mrlmd
Thanks for all the advice. Being aluminum should be a whole lot easier to work with than chrome plated. Just have to progressively sand the crap out of them 'till they are smooth and shiny, then recoat with clear. Sounds easy enough. Or have somebody else do it. I'm toying with the idea of Plastidip, and if I don;t like it, I can always rip it off and have the wheels refinished, It's only 2 of them that have these corroded spots on them so the job to clean them up is only half as bad.
To How can I fix these wheels?
Old Jul 28, 2018 | 01:03 PM
The Rabbi's Avatar
The Rabbi
2018 C5 of Year Finalist
St. Jude Donor '14,'18
Another idea. My used vette came with aftermarket chrome wheels. They all had pitting around the stem holes and after 100k miles were dull. I bought a set of chrome replicas from RPI for $800 shipped and sold my old ones for $250. For $550 net cost it was a great deal. Once I was quoted $800 to rechrome.
Old Jul 28, 2018 | 02:39 PM
Time for a C-5's Avatar
Time for a C-5
Strip the clear coat and polish. High polished aluminum will shine like chrome. Without the clearcoat it will also need to be repolished frequently.
Old Jul 28, 2018 | 02:54 PM
c5arlen's Avatar
c5arlen
Strip and then chrome my vote.. Not black!
