2001 Corvette engine problem
Old Jul 30, 2018 | 07:42 PM
reedysj's Avatar
reedysj
1st Gear
Default 2001 Corvette engine problem
I believe a rod or something blew a hole through the bottom of my oil pan in my 2001 5.7L V8 Corvette. What is an approx figure for getting this fixed?
Old Jul 30, 2018 | 07:58 PM
grantv's Avatar
grantv
Depends on how much you do. Are you looking to just buy a motor and install, if so used or new...? Paying someone else entirely? Again, used or new motor?
A few options. Guessing a low of $4-5K if you buy used and install.
Old Jul 30, 2018 | 08:04 PM
3sACROWD's Avatar
3sACROWD
If the damage came from within, you're likely looking at an engine replacement ($5k - $10k) depending if you buy a new or used engine and who does the work. If the damage was caused externally and you didn't run the engine dry of oil, you're likely in the $500 range.
Note:. Estimates are my best guess and not based on research.
Old Jul 30, 2018 | 09:35 PM
JR-01's Avatar
JR-01
Post picture of hole.
Old Jul 30, 2018 | 09:43 PM
grantv's Avatar
grantv
Eloquently said.
Old Jul 30, 2018 | 10:00 PM
Should be a pretty close guesstimate. Sorry to hear about the damage to your engine.
Old Jul 30, 2018 | 10:15 PM
redzg's Avatar
redzg
You can, of course, get it on the road for less than $4K. Pretty much any used 24x reluctor Gen. III engine will fit, some will respond well to the LS intake and exhaust and produce more power than in the original application. If you do a search on the forum, you will find those who have swapped in 5.3s to hold them while they built other motors, and others who just run 5.3s.
This site has some great information of which engines are which:
https://www.onallcylinders.com/2017/...engine-family/
Old Aug 1, 2018 | 06:59 PM
BRKLYN's Avatar
BRKLYN
Sorry for the mishap, hope your back and running soon.
To 2001 Corvette engine problem
