Convertable Adjustment
Old Aug 3, 2018 | 06:42 AM
PCorona's Avatar
PCorona
3rd Gear
Default Convertable Adjustment
passenger side at B pillar leaking like A water fall
behind the seatbelt assembly
could this be due to a convertable top out of alignment
Old Aug 3, 2018 | 09:23 AM
sirdano's Avatar
sirdano
Best bet is to take offf all covers in that area and have someone spray water and see where it is coming fro.
I keep having the same leak there. It was were the top meets the body next to door/glass. I actually lower the top and adjusted the pivot more to the front. I have daughter spray in that area and leak was gone. You might also check to make sure drain hole are clear.
Here is the adjustment procedure.
http://www.corvetteactioncenter.com/...-tips-831.html
Here is another great post
That fist picture is were mine was leaking.
https://www.corvetteforum.com/forums...eak-fixed.html
Any question feel free to reach out to me
