1998 Corvette EBCM Module repair/replacement?
Old Aug 9, 2018 | 12:50 PM
budb's Avatar
budb
8th Gear
Default 1998 Corvette EBCM Module repair/replacement?
I have been looking for a replacement EBCM with Active Handling for my 1998 Corvette conv. The ABS and Active Handling lights on the dash stay on constantly. I had it diagnosed for repair but, the code C1255 is not repairable and GM discontinued making this EBCM.
Any suggestions for solving ??
Bud
Old Aug 9, 2018 | 01:29 PM
SG Lou's Avatar
SG Lou
Look in the C5 Parts For Sale / Wanted.... Contact forum member Marc Rose at https://vettenuts.net/ He owns a Corvette Recycling Yard.
Check on eBay. I'll tell you one thing that is as certain as it will be dark tonight.....the chances of finding a new one is slim to none. As you found out, rebuilding is not an option so used is the only game in town and.............be prepared to shell out anywhere from $800 to over $2k, depending on who's selling it.
Don't believe me ? Do an eBay search. You'll be shocked.
Old Aug 9, 2018 | 01:32 PM
SG Lou's Avatar
SG Lou
Here ya go.....hope you're sitting down :1997 - 2000 Corvette C5 ABS Module EBCM V code ACTIVE HANDLING 09353631
Seller information
corvette_ca (421 )
99.2% Positive feedback
Conditionsed
Price:
US $2,199.00
$106 for 24 months *
Buy It Now-
Add to cart-
Best Offer:
Make Offer-
Old Aug 9, 2018 | 01:43 PM
SG Lou's Avatar
SG Lou
https://www.ebay.com/sch/i.html?_fro...dule+&_sacat=0
Old Aug 9, 2018 | 01:46 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There is a successful conversion to the late model 2001-2004 EBTCM that you can install .. Its a big job but it doable.
If it were me, i would seriously look into that.
Bill
Old Aug 9, 2018 | 01:58 PM
grampi50's Avatar
grampi50
Or you could just extinguish the warning lights and drive without it...unless you're in a state that requires it to be functional in order to pass a safety inspection of course...
Old Aug 10, 2018 | 08:51 AM
SG Lou's Avatar
SG Lou
Ya know, for a guy who DOESN'T own a C5 and who asks tons of questions on how to make sure you're gonna buy the best C5 for your buck, with the least amount of problems, you sure know how to give advice on using Duct tape and Bailing Wire to fix a problem.....SMH
Old Aug 10, 2018 | 08:56 AM
budb's Avatar
budb
8th Gear
How do I determine what active handling code mine is?
Old Aug 10, 2018 | 09:08 AM
naturaldisaster3's Avatar
naturaldisaster3
Old Aug 10, 2018 | 10:47 AM
grampi50's Avatar
grampi50
Whether I own a C5 or not is irrelevant. I can read. And maybe it isn't worth $2k for the OP to have functional ABS, traction control, and active handling (if so equipped)...why are you always so grumpy?
Old Aug 10, 2018 | 12:00 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Couple of ways to determine if you have Active Handling:
1. Check your RPO list and see if code JL-4 is listed. This is the RPO code for Active Handling.
2. Look at the button on the console in front of the center arm rest. It will either say Active Handling or Traction Control. If it says Active Handling you should have that option (unless a prior owner swapped out that portion of the console).
If you have AH you can double check that it is working by pressing and holding the Active Handling button for 5 seconds- WHEN YOU ARE STOPPED. If AH is working your will see Competitive Driving display on your DIC. This will disable traction control but allow the AH to continue monitoring the Steering Angle and Yaw Rate Sensors and the Lateral Accelerometer and apply single wheel braking as needed. You can also turn off AH by pushing and releasing the button. Even though AH is off you will still have anti-lock braking.
This was about a $500 option so many people (and dealerships) passed on it. If you have it, you will need the V code EBCM.
Old Aug 10, 2018 | 12:36 PM
budb's Avatar
budb
8th Gear
Thanks for the reply. I will look into this.
Old Aug 10, 2018 | 04:28 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Mr. grumpy....
Old Aug 10, 2018 | 08:01 PM
Alley Oop's Avatar
Alley Oop
I'm with grampi50. I also do not own a C5, but if I see an issue to which I have a solution, I'm going to speak up.
Old Aug 10, 2018 | 08:16 PM
jackthelad's Avatar
jackthelad
Except he is absolutely correct in what he said. Adding to that, insurance companies factor ABS and AH into insurance rates - they both generate "discounts". If they are not working, and you knew it, don't expect them to be sympathetic when you make a claim.
p.s. I however DO own a C5 - a '98, owned from new, but pre AH, which turns out to be a good thing in terms of ECBM failure rates. Happy to be critiqued by anyone who has owned one for longer, i.e.built before 1997.....
Old Aug 11, 2018 | 09:56 AM
Phanni's Avatar
Phanni
Call John Llewellyn at 865-604-0498
I believe he has one (used), and he does stand behind his parts.
These parts are rare, since they are non repairable, and no longer made my GM.
He'll give you a price, if he has one.
With most EBCM failures you not only lose active handling and traction control, but you lose the anti lock braking too. Extinguishing the lights on the dash only avoids the irritation of the reminder that your car isn't functioning properly.
Some folks here are giving terrible advice.
Old Aug 11, 2018 | 10:10 AM
Phanni's Avatar
Phanni
I just called John, he does have a couple of them,
The price he gave me is quite a bit cheaper than the Ebay ad above.
Good luck.
To 1998 Corvette EBCM Module repair/replacement?
Old Aug 11, 2018 | 10:58 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Old Aug 11, 2018 | 12:23 PM
SG Lou's Avatar
SG Lou
The problem there is the solution is bad advice.. Look the other way and ignore it or don't worry about it is not a solution.
Old Aug 11, 2018 | 12:26 PM
SG Lou's Avatar
SG Lou
Thanks Guys, I'm glad to see those who wish to speak up speak the truth.
