spark plug specs
Old Aug 15, 2018 | 07:26 PM
radc5's Avatar
radc5
Default spark plug specs
Anyone know the spark plug torque specs for a 2003 z06, and the spark plug gap size ?
Old Aug 15, 2018 | 07:41 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
You should be using .040 gap for your plugs. Most replacement plugs are coming with this gap already.
There was a Service Bulletin several years ago addressing the changed gap. TSB 03D-J-171 reads "A new spark plug has been released for use in the above vehicles.(Corvette 97-04) The new spark plug has an Iridium tip instead of the current Platinum tip. Due to the different tip design, the gap of the spark plug has also changed. The new spark plug, ACDelco Part Number 41-985 (12571164), is gapped to 1.01mm (0.040 inches) when the spark plug is made. The spark plug gap is set during manufacturing and should not be changed to the gap required with the Platinum plug, or damage to the spark plug may result." NGK TR-5 plugs (also commonly used in the LS engines is pre-gapped at .040” also.
Torque your plugs to 11 ft pounds.
Be sure to use anti-seize on the spark plug threads.
