Led Fog Light Bulbs
Old Aug 15, 2018 | 10:17 PM
gmbal4's Avatar
gmbal4
Default Led Fog Light Bulbs
Hey guys I got my bulbs in and installed the low beams and the fog lights. The low beams are fantastic a difference between night and day. However my fog lights has the out put of a dull candle ?? It`s pretty late so I`m not going to see what happened my question is can they be put in backwards ?? I thought for sure I installed everything correctly well anyway guys thanks for the input.
Old Aug 16, 2018 | 08:41 AM
Phanni's Avatar
Phanni
Can we assume you're installing HID lights?
Old Aug 16, 2018 | 09:02 AM
gmbal4's Avatar
gmbal4
The bulb replacement is called Auxito they are a direct replacement for the factory foglight bulbs after work today I will go back and double check what I did may be they are backwards or something.
Old Aug 16, 2018 | 11:48 AM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
If you placed the bulb forwards into the fog light socket it is installed correctly. I'm not sure you could even install it backwards and get it to seat and lock in to the socket. Perhaps the dealer sent you incorrect bulbs without much wattage?
Old Aug 16, 2018 | 12:28 PM
GCG's Avatar
GCG
The Auxitos are mentioned in this post from your other thread.
There is also valuable info on this write-up.
Old Aug 16, 2018 | 07:26 PM
gmbal4's Avatar
gmbal4
will check today when I get off from work before the sun sets maybe I plugged them in wrong or something because they are so DIM you can`t see if they are on unless you are standing right in front of the car
Old Aug 16, 2018 | 08:02 PM
gmbal4's Avatar
gmbal4
Well got home double check my connections and everything is connected correctly these fog lamps are TERRIBLE. I think a candle has a brighter light output than these
Old Aug 16, 2018 | 08:18 PM
gmbal4's Avatar
gmbal4
well I`m going to pull the plug and go with radio flyer Led bulbs for the fogs because these are terrible !! Also the link told me that the bulbs that I purchased is not compatible with my car ?? ...maybe thats the problem
Old Aug 17, 2018 | 02:00 AM
GCG's Avatar
GCG
Did you check what _zebra did for just 10 bucks (links in Post 5 above)?
Old Aug 17, 2018 | 05:46 AM
runner140*'s Avatar
runner140*
Add to the confusion...is there any chance your fog light LENSES are not clear but frosted b/c mine were.
Old Aug 19, 2018 | 12:39 PM
gmbal4's Avatar
gmbal4
yes they are a little frosted however the stock bulbs that were in here were brighter
To Led Fog Light Bulbs
