Optima Red Top owners?
Old Aug 22, 2018 | 10:42 AM
royal flush's Avatar
royal flush
Default Optima Red Top owners?
How do you maintain your battery--keep it on a Battery Tender? or let it sit when not driving for afew days or weeks--
Old Aug 22, 2018 | 10:56 AM
jcgunn's Avatar
jcgunn
I found that the longest I could go without putting the Red Top on a battery tender was about 3 weeks. Longer than that and it would be dead.
Old Aug 22, 2018 | 11:08 AM
c4cruiser's Avatar
c4cruiser
Don't have an Optima battery but I always keep my C5 battery on a tender I use a Deltran Battery Tender Junior; I wired in the cable to the "B" positive post on the fuse block and a good ground. The cable has a connector that can be disconnected quickly when I want to drive the car. C5's do tend to cause batteries to go dead after 3-4 weeks because of the small constant current drain.
With the Optima battery, you should look for a maintainer that works with that particular battery brand. Deltran and CTEK both will work..
Old Aug 22, 2018 | 11:49 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I always have kept my Red Tops on those Schumaker float chargers (it's just what I happened to own). Current one is several years old and still plugging along. Had a couple others last in the 8-9 year range this way.
Old Aug 22, 2018 | 12:02 PM
royal flush
You say 8-9 years is that the battery or charger your talking about?
Old Aug 22, 2018 | 12:14 PM
jglassmaker's Avatar
jglassmaker
If car sits for more than 2 weeks I will put it on a tender, but I have probably gone 3-4 weeks a few times without issues starting. I've had the red top install for 3 years now.
Old Aug 22, 2018 | 12:32 PM
The Rabbi's Avatar
The Rabbi
2018 C5 of Year Finalist
St. Jude Donor '14,'18
The motors need to be run regularly. Just saw an '03 on the lift getting new fuel pumps with just 30k miles. Tech said it's because of the ethanol and Stabil won't help that. Just run the motor until it warms at least every 2 weeks.
Old Aug 22, 2018 | 12:35 PM
Grandpa1's Avatar
Grandpa1
I don't drive my 03 very everyday so when I pull it in the garage I hook up my tender. Takes about a minute. I can see the lights on the tender start flashing when the the battery is full and being maintained.
My Red Top is about 3 years old.
Never have to worry about it.
Old Aug 22, 2018 | 12:41 PM
GCG's Avatar
GCG
I use a Deltran Battery Tender Plus. It's part of my routine when I pull into my garage.
Old Aug 22, 2018 | 12:42 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
I have a yellow top in my Vette and a red top in my truck. Yellow top is about 4 years old and my red top is approximately 10 years old. I have a CTech on the Vette and a Battery Tender on the truck. I plug them in maybe once a month over a weekend just because. My truck gets driven less then the Vette. I'm really surprised my truck battery has lasted that long down here in the Arizona heat.
Old Aug 22, 2018 | 12:48 PM
royal flush
So you have on maintainers 100% of the time when parked in garge until driven again and than back on charger? how many years have you gotten out of your red top?
Old Aug 22, 2018 | 02:04 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
C-Tek 4.3 MUS. Works keen!
Old Aug 22, 2018 | 02:45 PM
smuggler85's Avatar
smuggler85
I got 10 years out my original OEM Z06 battery and replaced it 4 years ago. My car is always on a Deltran Battery Tender when not being driven.
Old Aug 22, 2018 | 04:06 PM
Golfingbob's Avatar
Golfingbob
Does leaving the tender on for extended times cause any damage too the electronics?
Old Aug 22, 2018 | 04:19 PM
bj1888's Avatar
bj1888
No. Shouldn't cause any problems unless there's a problem with the tender itself.
My dad and I have our C5s hooked up to a
BatteryMinder BatteryMinder
using a Y-cable. It can handle up to 8 batteries at once.
Old Aug 22, 2018 | 04:45 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
Both! I've had the Schumaker float charger since about......probably 2007. I had two Red Tops at the time that were purchased in 2002 and finally died in 2010 and 2011 respectively, and it was honestly my fault because I wasn't float charging them enough (I.E. letting them go dead from time to time).
Old Aug 22, 2018 | 05:31 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
My red top is about 2 years old. If I know it's going to be more than a week between driving I hook it to the charger. Use the Optima Digital 400 (our son is an Optima dealer so I got a good price on it ).
To Optima Red Top owners?
Old Aug 22, 2018 | 06:14 PM
Fcar 98's Avatar
Fcar 98
My red top is going on 2 years in the car. Just sat a month and started right up. My car never sits with a tender and in 20 years no matter how long it sits. Only twice it did not start. And that was on 5 year old batteries. In my opinion it is not the batteries fault but the cars if it does not start after periods of sitting. During the winter months my car sits for two three months at a time.
Old Aug 22, 2018 | 06:29 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I don't drive my '01 C-5 on a daily basis, but I do get it out and fully warmed up, at least twice a week, during the summer. It's had an Optima Red Top in it since '02, due to the battery issues that were going on, back then. I usually keep a red top in the 'Vette for 4 years, then move it on to what I'm driving in the winter, and put a new one in the 'Vette. However, I have an Optima charger, and put it on the 'Vette one a week, during the winter....usually when I'm out running the snow blower around.
Old Aug 22, 2018 | 06:36 PM
Millenium Z06's Avatar
Millenium Z06
Moderator
I do, charges until 100% then goes into maintaining mode
