Doh!
Old Aug 30, 2018 | 09:20 AM
willriskit's Avatar
willriskit
Default Doh!
Bought a low mileage 2002 C5 that had belonged to the dealer's brother. The car is like new and as near as I can tell, flawless. The only problem is that it had a tape deck which I replaced myself with an OEM Bose CD player purchased on the forum and surprisingly, didn't screw anything up. Long story short, the car came with the extra top stowed in the rear and after a month or so, I decided to switch tops. Once I removed the other top from its storage place I discovered three storage compartments. The middle one contained a 12 disc CD player still in the plastic which gave my son a good chuckle.
Old Aug 30, 2018 | 09:45 AM
Xavierbank's Avatar
Xavierbank
Send us a pic of what you are talking about........
Old Aug 30, 2018 | 09:54 AM
JR-01's Avatar
JR-01
His car came with the CD changer in the trunk which means there is no CD player in the dash. He put in the dash CD player which he did not need to do. Probably should have checked his car out a little better before swapping dash unit.
Old Aug 30, 2018 | 10:18 AM
Always pays to check the car over thoroughly - but you did get a nice surprise.
Old Aug 30, 2018 | 11:18 AM
Velocity_Vette's Avatar
Velocity_Vette
The OEM CD changer in the trunk is notorious for having issues, even on low mileage cars. As GM has exhausted all their OEM supplies for it also if it happens to fail then most owners are typically SOL unless they can source a good used unit.
And yeah this is one of those things that would have paid to do a little research. C5s were equipped with two Delco stereo options. Either they came with the single CD player or the tape deck with CD changer in the rear.
Old Aug 30, 2018 | 11:37 AM
Cutlassmaster's Avatar
Cutlassmaster
My 99 came with CD changer in trunk along with a CD in the head unit. I've had no issues with changer in the trunk and use it all the time.
Old Aug 30, 2018 | 11:58 AM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Oh the huge manatee...
Old Aug 30, 2018 | 12:20 PM
Patches's Avatar
Patches
I took the changer and mounting brackets out of the back of my 7,700 mile coupe when I was transferring the battery to the rear center compartment. The changer has probably less than ten hours of play on it so is essentially new. I will either sell it or give it as a backup to my buddy who has one in his 99 FRC.
Old Aug 30, 2018 | 12:27 PM
JR-01's Avatar
JR-01
That surprises me. I have have been playing my CD changer 99% of the time for the last 5 years and 30K miles. It is 18 years old and has not missed a beat. That's a pretty good record. I also only use burned CDs that I burnt myself. I have three cartridges that I rotate in. I do take the cartridge out and put them all in the house when I put the car away for the winter.. Probably lack of use and leaving cartridges in over the winter causes the problems.
Old Aug 30, 2018 | 12:41 PM
Black03vert's Avatar
Black03vert
Sell the 12 Disc CD Player on eBay or on here. You might get $200 for it
Old Aug 30, 2018 | 12:47 PM
Brunello's Avatar
Brunello
My cd changer was a surprise as well- as were all the other options on my 99. I guess it’s a first Corvette rookie mistake. Car looked so good, I just bought it. Got lucky either way!
Old Aug 31, 2018 | 09:01 AM
willriskit's Avatar
willriskit
It'll come in handy on long road trips. When I told the salesman that I'd have to switch-out the tape deck for a CD player he opined that it would be an inexpensive proposition so he most likely didn't know about the 12 disc as well. Couldn't be happier with the car!
Old Aug 31, 2018 | 09:06 AM
02BlownZ06's Avatar
02BlownZ06
Lol, that's a "Doh!" moment for sure!
To Doh!
